Hard Drive Storage Configuration
By
Guest
in Storage Devices
in Storage Devices
Solved by Godlygamer23,
how would I do that
Out-of-the-box, you need to open an application called Disk Management. After it launches, you should see an "Unallocated" section next to your hard drive. Right click on that and click New Simple Volume. Then just follow the on-screen prompts.
Macaw ·
Posted in Console Gaming3 -
3
Shahrad ·
Posted in LTT Releases2 -
4
frozensun ·
Posted in Graphics Cards7 -
kisserik93 ·
Posted in Peripherals11 -
Rick13 ·
Posted in CPUs, Motherboards, and Memory14 -
3
