Big system upgrade
Go to solution Solved by Lavish,
Oh, seriously? I mean, should I really wait that long?
They wont increase performance by alot, I would estimate about a 10% performance increase max. Skylakes main selling point is cooler temps and better power efficiency, but the cooling is bogus because it goes by stock cooling, so you wont see a insane temp decrease to the point where you will NEED this chip. If you can stand the wait though I would hold off, the prices on the older cpus are bound to drop after the release.
Hey guys, I've posted about this before, but this time I want to go into more detail. I have about 300 dollars with me. I want to buy a new CPU and some other things as well.
I was planning on buying this: http://pcpartpicker.com/p/MQ2MvK
Are these parts good enough for gaming until, say, late 2016? Any reccomendations, any opinions?
Also, I was wondering if it would be worth it if I waited until Labor day to buy my parts. The problem with that is that the free Windows Upgrade thing only lasts until July 29th. So should I buy the parts later, hope for a sale or something, and risk not getting Windows 10?
https://linustechtips.com/topic/410427-big-system-upgrade/
i5 4460
H97 motherboard
Late 2016 it will be fine at that point it will be ur GPU which will need the upgrade not the CPU
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
https://linustechtips.com/topic/410427-big-system-upgrade/#findComment-5526314
I actually can afford a Z97, should I go for it?
Nah ur CPU isnt unlocked so it wont matter
4690k and Z97 is the best option
https://linustechtips.com/topic/410427-big-system-upgrade/#findComment-5526330
Apparently the release date is August 5th. I'll definitely be waiting until then.
I believe thats the mobile chips, the enthusiast and gaming chips wont launch until early 2016
Intel i5 4690k | NZXT Kraken x61 | MSI z97 Gaming 5 | MSI GTX 970 EVGA Supernova G2 750 G-Skill Ripjaws 16GB 2133mhz [2x8] | Western Digital Caviar Blue 1TB HDD Samsung 850 EVO Series 250GB SSD NZXT H440 [black and Red]
Saving for a Dream rig :)
https://linustechtips.com/topic/410427-big-system-upgrade/#findComment-5526508
https://linustechtips.com/topic/410427-big-system-upgrade/#findComment-5526543
