I'm in the process of a new gaming pc build. I know a little bit but not enough where i'm comfortable with making the final say for everything. i will be gaming a lot on it but i still have a xbox one i will be getting bigger games on. I wanna stay with a blue and black theme so if you have any changes please keep that in mind. Thank you.
            this is what I have so far.
NZXT S340 Matte Black/Blue Steel ATX Mid Tower Case
ASRock Z97 Extreme6 LGA 1150 Intel Z97 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
EVGA 04G-P4-3975-KR GeForce GTX 970 SSC ACX 2.0+ 4GB 256-Bit GDDR5 PCI Express 3.0 SLI Support Graphics Card
CORSAIR HXi HX850i CP-9020073-NA 850W ATX12V / EPS12V 80 PLUS PLATINUM Certified Full Modular Power Supply
Intel Core i5-4460 Haswell Quad-Core 3.2GHz LGA 1150 BX80646I54460 Desktop Processor Intel HD Graphics 4600
SAMSUNG 850 EVO MZ-75E250B/AM 2.5" 250GB SATA III 3-D Vertical Internal Solid State Drive (SSD)
CORSAIR Dominator Platinum 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMD16GX3M2A1600C9
Western Digital Blue WD10EZEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive
CORSAIR Hydro Series H110i GT H110i GT Water Cooler
If it's just gaming you don't need 16GB of RAM
You don't need a watercooler because you have a non OC CPU which don't get hot so a stock cooler will do fine
That PSU is overkill a 600W or 550W will do fine
I would go for a 390 over a 970
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/410373-any-help/#findComment-5525709
step one make a video of you burring your xbox and if you get money from that you have more money for your pc  :)
CPUFX 8320, Motherboard ASUS M5A78L-M/USB3 Socket AM3+ AMD, RAM g.skill ripjaws x series (2x8gb), GPUstrix gtx 970, Storage 500gb + 500gb + 250 ssd, PSU EVGA 600w B 80 PLUS BRONZE, Display(s) ASUS VG248QE 24"+ Hisense 24" + Vizio 24", Cooling Cooler Master Hyper 212 EVO, PC Part Picker  http://pcpartpicker.com/p/LFxQ23
https://linustechtips.com/topic/410373-any-help/#findComment-5525713
Get a different motherboard. Too overkill for a non-OC CPU
Try this: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157512
CPU Intel i7-4770k @4.4Ghz Motherboard ASUS Maximus VI Hero RAM Corsair Dominator Platinum 1866Mhz 16GB GPU MSI GTX 970 GAMING 4G Case Corsair 760T Storage Samsung 840 EVO 250 GB + 2x WD Black 1TB PSU Corsair AX860 Display(s) AcerXB1, QNIX QX2710                         Cooling Corsair H105 Keyboard Corsair K70 Cherry MX Red + Red LED Mouse Logitech G700s Sound Beyerdynamic MMX300
https://linustechtips.com/topic/410373-any-help/#findComment-5525719
i wanna end up replacing my xbox so i can do adny game on it
https://linustechtips.com/topic/410373-any-help/#findComment-5525723
I'll build a list for you. BRB and space reserved with this post.
EDIT: OK, you get a 4690k and a GTA 980 Ti as well as a fully color-matched system :)
CPU Cooler: Phanteks PH-TC12DX_BL 68.5 CFM CPU Cooler  ($59.99 @ Amazon)
Motherboard: ASRock Z97 EXTREME4 ATX LGA1150 Motherboard  ($128.88 @ OutletPC)
Storage: OCZ ARC 100 240GB 2.5" Solid State Drive  ($89.00 @ Amazon)
Video Card: Gigabyte GeForce GTX 980 Ti 6GB Video Card  ($649.99 @ SuperBiiz)
Case: NZXT S340 (Black/Blue) ATX Mid Tower Case  ($59.99 @ Micro Center)
Total: $1457.70
Generated by PCPartPicker 2015-07-18 19:29 EDT-0400
https://linustechtips.com/topic/410373-any-help/#findComment-5525726
@mp7jokers Follow your topic
        Setup
https://linustechtips.com/topic/410373-any-help/#findComment-5525727
8gb will be fine
https://linustechtips.com/topic/410373-any-help/#findComment-5525728
is a non oc cpu ok or no?
yes and no. if you do not care for spending time to over clock it then it is fine. it will not do much for your gaming if you over clock your cpu. for you it should just be fine
https://linustechtips.com/topic/410373-any-help/#findComment-5525791
Like Pcinacan said, but if you do desire to overclock then I'd recommend trading the motherboard for this http://www.newegg.com/Product/Product.aspx?Item=N82E16813157506 as well grabbing a 4690k (The two total to about the same price as your original motherboard + CPU combo)
https://linustechtips.com/topic/410373-any-help/#findComment-5525803
oh ok
In my build I put 16GB in there for the heck of it since you have the money for it and you still have money left over. I also put a 4690k and Z97 board in there as well as a good CPU cooler so you can overclock it.
https://linustechtips.com/topic/410373-any-help/#findComment-5525809
What if i wanted to do video recording and editing too?
A 4690k and 980ti will do that fine but you may want the extra threads of a 4790k. Totally up to you.
https://linustechtips.com/topic/410373-any-help/#findComment-5525816
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117372&cm_re=4690k-_-19-117-372-_-Product ?
https://linustechtips.com/topic/410373-any-help/#findComment-5525826
If he's gaming @ 1080p , a GTX 980 Ti is overkill IMO. I already get pretty decent FPS in games with a GTX 970 @ 1440p
https://linustechtips.com/topic/410373-any-help/#findComment-5525832
Yes. It would perform much better than the i5-4660 especially when gaming and in video editing.
https://linustechtips.com/topic/410373-any-help/#findComment-5525843
the 980ti is almost double the price of a 970. can i just do two 970's or is that over kill again?
Well if you're gaming at 1080p what I would do is buy a 980 and a new monitor (like either a second monitor or a larger 1440p/4K one) with the money left over and not a 980ti.
https://linustechtips.com/topic/410373-any-help/#findComment-5525849
Lol no...
He would need to overclock it like mad to see much of a difference.
https://linustechtips.com/topic/410373-any-help/#findComment-5525855
i was doing the water cooling cause i thought it would help with it staying cooler while i game. i tend to game for 4-6 hrs on days i work and 8+ hrs when im off
Air cooling will still keep it cool. Water cooling is more dangerous, harder to keep clean and has no effect on a CPU where the mulitplier is locked.
https://linustechtips.com/topic/410373-any-help/#findComment-5525860
