driver problems
Go to solution Solved by SkixAces,
thats not what i am trying to do and theres no online drivers for my thing
Just copy the drivers from the disc to the usb, and run the .exe file
i was wondering if it was possible to transfer drivers from a disk to usb and if so how
If you want to copy the drivers from the cd the motherboard or graphics card came with, I suggest you dont. Just download them from the site to get the most updated drivers
System: CPU - I5-6500 Motherboard - Asus B150M-A RAM - Crucial ballistix sport 2x4GB DDR4 @2400MHz GPU - RX 480 PSU - Seasonic S12II 520W Case - Aerocool Aero-800 HDD - Seagate 1TB SSD - PNY CS1311 120GB Monitor - AOC G2260VWQ6
https://linustechtips.com/topic/410349-driver-problems/#findComment-5525419
https://linustechtips.com/topic/410349-driver-problems/#findComment-5525452
