Not if they are in the original packaging and well taken care of.
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/410196-static-and-storage/#findComment-5523837
They probably sit on the storage shelves in warehouses/shops for ages anyway aha, it'll be fine. There was a 2 month gap between the time I brought my 1st part and built my 1st build lol
i5 4690k | GTX 980Ti G1 Gaming | 16GB RAM | MSI Z97 Gaming 7 | NZXT Kraken X61 | 850 EVO 250GB x2  | 1TB 850 Evo NZXT Noctis 450 | EVGA 750W 80+ Gold
 Ducky Shine 3 TKL (Browns) | LG 34UC87C | Logitech MX Master ATH-M50x's + DT990 Pro's
https://linustechtips.com/topic/410196-static-and-storage/#findComment-5523852
hi i have been buying my pc parts but i dont have them all will my parts become damaged or build up static if left not used as i could not get my parts all at once
As @Swegly mentions, just leave them in the original packaging that they came in. You won't have any issues.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
https://linustechtips.com/topic/410196-static-and-storage/#findComment-5523856
and this is of topic but my mother board has 2 4+4 cpu slots together dose that mean i have to plug them both in or leave one unpluged
Plug in every power cable connector that your motherboard has. Some higher end boards have optional power connectors, but it's always safest to plug them all in.
https://linustechtips.com/topic/410196-static-and-storage/#findComment-5523907
Better to save and buy all parts at once so that you will be able to test and benchmark them for any problems. Also you could get good deals and discounts when buying all components at once.
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
https://linustechtips.com/topic/410196-static-and-storage/#findComment-5523952
it has an 8 pin slot for cpu power do i but both 4+4 to plug 8 pin or just plug 4 pin leaving a 4 pin slot exposed
I already answered this. Plug both in.
https://linustechtips.com/topic/410196-static-and-storage/#findComment-5523990
