Hey guys i was using a air duster and i as spraying my pc and accidentally the liquid came out and went into my titan x gpu fan and on my motherboard but on my mobo it dident go inside anything it was just like a black wall thing with the name asus on it. Is everything fine?
https://linustechtips.com/topic/410154-computer-help/
Yes, happens all the time to me :P
https://linustechtips.com/topic/410154-computer-help/#findComment-5523325
But what if the liquid goes inside the gpu and motherboard? Is everything then fine?
|Intel Core i5-4670K| |Gigabyte Z97P-D3| |Seagate 1TB SSHD| |Fractal Design Define S| |Corsair CS650M| |Asus PB278Q| |Cooler Master CM Storm Devastator Bundle|
https://linustechtips.com/topic/410154-computer-help/#findComment-5523332
Wait until you are sure everything is dry and then boot it up again if you're skeptical.
#RIPTopGear  This is the best thread ever: http://linustechtips.com/main/topic/53190-i-can-not-get-hard/ " French meetings are just people sitting in a semi-circle shouting at each other" -Dom Jolly  :lol:
My rig:
   CPU: Pentium G3258 @ 4.5GHz GPU: GTX 760 reference | PSU: Corsair RM750 Cooler: Cooler Master Seidon 120V | Motherboard: Gigabyte B85M D3H | Case: NZXT S340 White | RAM: 8GB EVO Potenza @ 1600MHz Storage: 3TB Seagate HDD, 60GB OCZ SSD, 620GB Toshiba HDD | Mouse: Steelseries Rival @1000 CPi |  OS: Windows 10 Pro Phone: iPhone 6S 16GB
http://linustechtips.com/main/topic/439354-why-nvidia/
https://linustechtips.com/topic/410154-computer-help/#findComment-5523355
