Maybe the fan when it hits a higher RPM. Does it do it instantly as soon as a decent load is put on it?
https://linustechtips.com/topic/410048-psu-noise/#findComment-5522183
Fullload starts the noise.idle there no noise.
Can you record it somehow? Video or pure audio is fine.
https://linustechtips.com/topic/410048-psu-noise/#findComment-5522204
U cant hear it my system is too loud
How loud is your system? If you put the microphone right at the unit(perhaps in the back), you might be able to pick it up.
https://linustechtips.com/topic/410048-psu-noise/#findComment-5522230
It might be the fan, if it only appears under load it's probably the high RPMs of the fan.
https://linustechtips.com/topic/410048-psu-noise/#findComment-5522271
Too loud to pick it up
Then my best guess is the fan.
https://linustechtips.com/topic/410048-psu-noise/#findComment-5522290
Its there is something i can do?
Well, the power supply could also be rattling. The fan could be rattling, or it's just the motor of the fan. Try messing with screws around the unit and possibly on the case to see if you can make the noise go away. If it's the motor of the fan, there's nothing you can do without opening the unit.
https://linustechtips.com/topic/410048-psu-noise/#findComment-5522305
Ok that you for your help
https://linustechtips.com/topic/410048-psu-noise/#findComment-5522307
Don't open the PSU! It's dangerous and you might void your warranty/brick it.
If it's not louder than your system and if everything works fine, then it's probably not an issue.
I've not heard of Gigabyte making PSUs but idk how good quality they are. You can change it if it worries you so much.
https://linustechtips.com/topic/410048-psu-noise/#findComment-5522328
Don't open the PSU! It's dangerous[.]
Only if there's a charge. If it's completely discharged, it's no more dangerous than any other component in your PC.
https://linustechtips.com/topic/410048-psu-noise/#findComment-5522342
But he could also brick something and when hooking it back up it could do damage.
If you have no idea what you're doing, avoid opening PSUs.
https://linustechtips.com/topic/410048-psu-noise/#findComment-5522351
I wont open it i cant decide to change it
https://linustechtips.com/topic/410048-psu-noise/#findComment-5522437
If you have no idea what you're doing, avoid touching computer components altogether.
https://linustechtips.com/topic/410048-psu-noise/#findComment-5522440
Underload(gpu,cpu) my gigabyte greenmax 650w 80+ bronze make some brrrrrrrrrr noise.can someone tell what cause the noise.its 1 and half month used.
The GreenMax has been known to have a loud fan.
It's eh. GreenMax is better then Corsair VS, worse then CX..
"Rawr XD"
https://linustechtips.com/topic/410048-psu-noise/#findComment-5524696
Then I'm not surprised if the PSU is making noise. It's likely normal.
https://linustechtips.com/topic/410048-psu-noise/#findComment-5524710
