Minimum CPU for streaming
Go to solution Solved by Homicidium,
I'd probably suggest a lower end i5 or one of the i3's with HT.
Well any CPU can do it just looking at what has better performance for it. Is it in a separate streaming pc or in your everyday pc?
as opposed to an i3 without HT
Which is a pentium! :P (I know you were JK)
|| Asrock Z68 Extreme 3 Gen 3 || i5 3570 @3.5GHz || Zalman CNPS10X Optima || 8GB RAM HyperX Fury Blue @ 1600MHz || Thermaltake Berlin 630W || Zalman Z11 || Gainward Phantom GTX 970 || 120GB Kingston V300  (Gift) + 1TB  WD Green
Phone: Xiaomi Redmi Note 8
Tablet: iPad Mini 2
For streaming + playing games, i suggest either Nvidia card + i5, or AMD card with FX 8370e (yes, specifically the "e" version). The FX should only EVER be used, if you already have an AMD mobo, or you want to go full budget (FX 8370e is a 95w CPU, it can run off any 970 board and doesnt require a beefy 8+1 power delivery).
But as a rule of thumb
BUY AN i5
and if you are still in doubt
BUY AN i5
And if you still think that isnt good enought
BUY AN i7
and if you cannot afford a i7
GET A LGA 1150 XEON
and if you still arent happy - get the FX and come back here asking for a new CPU in 3-4 months time.
