Hi there im writing this on behalf of a friend and in his prospective
I have recenlty invested in a new power supply and graphics card  i went for the power x3 pro endition 800w and an MSI GTX 960 im not that confident when it come to building pc but i decided to give it a shot i have plgged in what i think is all the cables and i asume are in the right places but when ever i power on the system it will switch itself off almost immediately all the main cables have been conected and are what i asume ahve been done correctly the motherboard im using for this is the gigabyte ga-f2a88xm-ds2 all the components have been installed correctly because i never had any problems before using the system untill now dose any body think the could know what the problems could be cause by any help will be really appricated
thank you :)
https://linustechtips.com/topic/410030-problems-when-upgrading/
Is all other hardware the same? Your power supply is also likely no good - no 800W unit will retail for 30USD. Another question...why did you purchase an 800W unit for a system based around the 960?
https://linustechtips.com/topic/410030-problems-when-upgrading/#findComment-5521979
i completely agree with u but it was because another one of his friends told him to prob because it was a lrage Wattage i dont think they looked to much in to why you dont cheap out on PSU any way the system worked perfect before only running a AMD A8-6600k and the 8gb ram thats init i feel like the main problem could be its been wired wrong or a bad PSU assuming tis probably both
https://linustechtips.com/topic/410030-problems-when-upgrading/#findComment-5522034
Cheaping out on a power supply is one of the worst things you can do - it can fry all of your components.
https://linustechtips.com/topic/410030-problems-when-upgrading/#findComment-5522056
It's probably your power supply. Sumvision is known as one of the companies to completely avoid buying power supplies from. Return it and get a good EVGA, Corsair, Cooler Master, etc.
i see his being right at the bottom he going to try and it send back and get a much better one as soon as
while under the subject of power supply im using a corsair cx 600w in my current system im running an i7 4790k OC4.2 GHZ and 16gb ram palit gtx 770 4gb i honestly dont know how this works but it dose should i look in to investing in to a better psu
https://linustechtips.com/topic/410030-problems-when-upgrading/#findComment-5522119
That power supply is fine. But for the upgraded system, get a better unit.
https://linustechtips.com/topic/410030-problems-when-upgrading/#findComment-5522127
