you may have to push so much volts to it because of instabilty somewhere else.
try this to begin. find stability at 4.4ghz, then push for 4.5.
follow this step by step, do not change anything else!
install latest bios
clear cmos
change your multiplier to 44 and your vcore voltage to 1.25V ( you may need 1.2,1.21,1.22,1.23, 1.24, 1.25, 1.26V)
set your ram at 1333MHz and manually input the stock voltage for your ram ( if your ram calls for 1.35V i would set it at 1.5V to start)
leave all other settings, dont change anything else.
try to boot and stress test with the ietu
start at 1.25V on the cpu vcore. keep incresing it in .01 increments ( 1.24,1.25, 1.26, 1.27, 1.28V) untill your stable for 8 hours. i dont suggest going past 1.28V for 4.4 GHz
Decrease your cpu vcore voltage if you find stability at 1.25V
only use the ietu to stress test
http://www.intel.com/content/www/us/en/motherboards/desktop-motherboards/desktop-boards-software-extreme-tuning-utility.html
I plan on posting an haswell oc guide\video soon
Mainboard Asrock Z170 OCF CPU 6700k RAM Tridentz 3600 HDD Intel 730 240gb GPU GTX 780ti sc acx PSU Silverstone Strider 1200W  Case Antec 900 Laptop Lenovo Thinkpad T520 build log-   http://linustechtips.com/main/topic/35809-antec-900-the-re-birth-of-a-legend/ Check out the Tech Center https://www.youtube.com/user/prokon24/videos LTT's Unicore King
