Haswell CPUs run hot, but 100c is dangerous for your CPU, maybe you should try reapplying your thermal paste. Why are you so set on 4.6ghz?
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
https://linustechtips.com/topic/41003-help-overclocking-a-4770k/#findComment-531243
Do not push the CPU voltages that far. You want a max of 75C. The recommended max voltage for Haswell is 1.35. What is the highest stabil overclock you have achieved? You might just have a bad overclocker on you hands.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/41003-help-overclocking-a-4770k/#findComment-531249
Do not push the CPU valtages that far. You want a max of 75C. The recommended max voltage for Haswell is 1.35. What is the highest stabil overclock you have achieved? You might just have a bad overclocker on you hands.
I haven't actually reached a stable over clock with this CPU yet but my last CPU was a 3770k which got stable at 4.2GHZ at 1.25v
https://linustechtips.com/topic/41003-help-overclocking-a-4770k/#findComment-531257
You shouldn't aim as high as 4.6GHz in the first run. Try and get something like 4.0GHz first to establish how well the chip overclocks.
https://linustechtips.com/topic/41003-help-overclocking-a-4770k/#findComment-531263
Would 85C be too high? I'm only overclocking because I have 2 GTX 680s, otherwise I wouldn't bother.
No 85C is still to hot. 75C is the recommended max temp
https://linustechtips.com/topic/41003-help-overclocking-a-4770k/#findComment-531280
Learn your CPU first. Baby steps.Personally I always start by under-volting the chip while it's running at it's stock frequency then I can establish at what "under-volted voltage" it's stable at and I start bumping it up from there.
Ok il start from there then
https://linustechtips.com/topic/41003-help-overclocking-a-4770k/#findComment-531281
I'm trying to get my CPU stable at 4.6GHZ and have tried setting the voltage from 1.200 to 1.400 doing 0.050 increases every time it failed and now the temps are reaching 100C while running prime95 and using a h100 CPU cooler, can anyone give me some advice?
Don't use prime 95 it is not validated for the new intel chips use Intel Extreme tuning utility download from here http://www.intel.com/content/www/us/en/motherboards/desktop-motherboards/desktop-boards-software-extreme-tuning-utility.html
Asus Maximus VI Extreme, I7 4770K, NZXT Kraken X60, Kingston HyperXBeast DDR-3 2400, Sapphire 6950, NZXT Phantom 820, SanDisk 120Gb Extreme x2 in Raid, 2Tb WD Green, SeaSonic X-850 Gold
https://linustechtips.com/topic/41003-help-overclocking-a-4770k/#findComment-531292
Downloading it now.
https://linustechtips.com/topic/41003-help-overclocking-a-4770k/#findComment-531305
While installing I just get an error saying "attempted to install on an unsupported platform!"
Edit : never mind.
https://linustechtips.com/topic/41003-help-overclocking-a-4770k/#findComment-531313
Thats weird i am running it on my Pc no issue, is this the one you downloaded https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3483&DwnldID=22835&keyword=%22%22extreme+tuning+utility%22%22〈=eng
https://linustechtips.com/topic/41003-help-overclocking-a-4770k/#findComment-531326
I must have downloaded it from the wrong place, iv got it now and its running good.
https://linustechtips.com/topic/41003-help-overclocking-a-4770k/#findComment-531331
This might give you a different temp range i don't get over 75 degrees doing this at 4.6 and 1.33V
https://linustechtips.com/topic/41003-help-overclocking-a-4770k/#findComment-531340
NZXT Phantom 820, I haven't got screws long enough.
Do you have it in the top or the bottom
https://linustechtips.com/topic/41003-help-overclocking-a-4770k/#findComment-531342
That thing's a beast! If you're using the stock fans that are included with the H100.......just don't!
What do you mean??
https://linustechtips.com/topic/41003-help-overclocking-a-4770k/#findComment-531390
