There is a number of fairly decent ssds in the 240GB within the same price range.  One in particular , Intel 730 series 240GB , which was 139 on newegg,ca.  but now that deal is finished , so on to the next best thing, imo, Sandisk Extreme Pro  http://www.amazon.ca/SanDisk-Extreme-2-5-Inch-Warranty-SDSSDXPS-240G-G25/dp/B00KHRYRNM.
Im talkin' Sata III , MLC son.
Let me know any notables , .........i need one today
https://linustechtips.com/topic/409548-question-240gb-range-ssds/
"LTT's official.."STOP. I promise you aren't LTT's official bagel eater or whatever. Trust me.
He's in canada...
My bad, here's the same drive for CDN$129, considerable cheaper than the sandisk.  http://www.amazon.ca/Samsung-2-5-Inch-Internal-MZ-75E250B-AM/dp/B00OAJ412U/ref=sr_1_2?ie=UTF8&qid=1437156197&sr=8-2&keywords=850+evo
Frickin,... I had forgot to look on the forums after i made another post here.   I appreciate your feedback .  That is a good deal and it is still on.  i think it uses 3d TLC or something , Similar to the 850 pro's 3d vertical nand  I wonder why the user reviews for both are not near as good as the 840 Pro and 840 Evo. Leave that for better minds than mine.  It is no matter anyhow . I have already purchased the Sandisk Extreme Pro.
If i had more funds to spend on a single drive i can see the 850 Evo 500GB or 1TB being the better buy.
