I Was playing TES : Skyrim and my game froze black screened and i clicked out of game and it fixed itself, a minute or so later it did the same thing but my FPS went down to 8-9 instead of the the usual 40 - 60. And i am lucky that i had MSI Afterburner on. So my gpu (7790 @ 1200MHz) After that weird crap happened the core clock is stuck at 300MHz and the Memory clock is at 150MHz instead of 1600?!?!
edit : i looked at when the first freeze happened and apparently everything went to the lowest clock it could :(
I'm the Forum Owl
*Who*
https://linustechtips.com/topic/40953-gpu-problems/
02, 30-07-2013 01:02:12, GPU temperature     ,GPU usage           ,Fan speed           ,Fan tachometer      ,Core clock          ,Memory clock        ,Memory usage
80, 30-07-2013 01:03:23, 35.000              ,0.000               ,20.000              ,1159.000            ,300.000             ,150.000             ,130.355
80, 30-07-2013 01:03:24, 35.000              ,0.000               ,20.000              ,1161.000            ,300.000             ,150.000             ,130.336
80, 30-07-2013 01:03:25, 35.000              ,0.000               ,20.000              ,1159.000            ,300.000             ,150.000             ,130.336
80, 30-07-2013 01:03:26, 35.000              ,0.000               ,20.000              ,1157.000            ,300.000             ,150.000             ,126.035
80, 30-07-2013 01:03:27, 35.000              ,0.000               ,20.000              ,1154.000            ,300.000             ,150.000             ,126.035
80, 30-07-2013 01:03:28, 34.000              ,0.000               ,20.000              ,1158.000            ,300.000             ,150.000             ,126.035
80, 30-07-2013 01:03:29, 34.000              ,0.000               ,20.000              ,1158.000            ,300.000             ,150.000             ,126.035
80, 30-07-2013 01:03:30, 34.000              ,0.000               ,20.000              ,1154.000            ,300.000             ,150.000             ,126.680
After the second freeze
I'm the Forum Owl
*Who*
https://linustechtips.com/topic/40953-gpu-problems/#findComment-530603
Your oc is too high. or maybe its stuck in ULPS mode you can disable it in AB if it lets you but idk.
PRIMARY NVIDIA PC
("I'm a Fanboy of Everything")
| CPU - i5-4670K @ 4.8ghz | CPU Cooler - Antec Kühler H2O 620 | GPU(S) - BIOS MODDED Twin GTX 770 4gb (Gigabyte)-master (Zotac)-slave @ 1337/2000 (8000 Effective) | Mobo - MSI Z87 GD65 Gaming | PSU - Corsair TX850M | Ram - 8gb Gskill RipjawsX @ 1866Mhz | Monitor - Samsung 27" 550 1080p 75Hz | Keyboard - Razer Black-Widow Ultimate 2013 | Storage - 2x 1TB WD-Blacks' | Mouse - AzzA Mouse Would Say "SQUEEKSQUEEK"|
SECONDARY RADEON PC
| CPU - A10-6800K @ 4.6ghz | CPU Cooler - CM Hyper EVO 212 | GPU(S) Twin Radeon 270x 2gb @ 1115/1500 (6000 Effective) | Mobo - MSI FM2-A85XA-G65 | PSU - Logisys 750W | Ram - 8gb @ 1600mhz | Moniter - Acer 24'' 1080p 60Hz
https://linustechtips.com/topic/40953-gpu-problems/#findComment-530613
Everytime a driver reset happened, i usually reboot my system.. else i'll get choppy performance.
You might want to increase your voltage for core or mem or both if TDR issue keeps happening.
https://linustechtips.com/topic/40953-gpu-problems/#findComment-534014
The only problem is that amd keeps you from increasing the voltage on the 7790
The card manufacturer does that. Not AMD specifically
PRIMARY NVIDIA PC
SECONDARY RADEON PC
https://linustechtips.com/topic/40953-gpu-problems/#findComment-536530
