best cheapest value case lights
Go to solution Solved by modguru,
Hi! I will recommend you take a look at our line of LED's. They are a high quality, long lasting LED. With the controller you need to use it you will get plenty of effects like the one you needed. You can check them out here:
Controller: https://modguru.net/product/rf-rgb-controller/
Strips: https://modguru.net/product/led-strip-rgb/
my build is:
PCPartPicker part list: http://ca.pcpartpicker.com/p/Wcdp4D
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($402.89 @ Newegg Canada)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($132.98 @ DirectCanada)
Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard  (Purchased For $0.00)
Memory: fury x
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($59.75 @ Vuugo)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card  (Purchased For $0.00)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  ($138.50 @ Vuugo)
Power Supply: Cooler Master VSM 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($109.99 @ Memory Express)
Total: $964.09
and im planning on having the corsair logo red and get a red led for the the GPU as well as my ram and my mobo being red (and case)
What are the cheapest leds that have a pulse as in the light comes in and fades and are not just light dots?
*It can be slightly expensive i just want the cheapest generally not a 5 led strip that will burn out quick*
also how will my build look? will it look good or nah
https://linustechtips.com/topic/409425-best-cheapest-value-case-lights/
Contact us for a quotation or a chat [Modguru shop] [Facebook] Creating the highest quality products ever
my build is:
Memory: fury x
Total: $964.09
The build looks good, but please, swap that seagate for a hard drive that doesn't have a 43% chance to die after a year. Seagates have very, very high failure rates. My suggestion would be a Hitachi (or HGST depending on model) drive, they have remarkable reliability. Best in the business actually.
And as our pal from modguru says, their RGB lights are fantastic. I've used em a couple of times, however, as will almost all of these kinds of led strips, the Adhesive sucks, major. If you're super careful with your computer and how you apply it, then it should be fine, but most of the time they'll start to peel off rather quickly. I'd suggest some aftermarket adhesive.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
Our RGB LED's has the highest grade adhesive that 3M makes. It will stick :)
