I recently upgraded my loop to include my 970, I put a new 240mm rad and now I wanna get rid of the stock fans for them.
My rig is a black and Red setup (used mayhem pastel red coolant)
So I want to know if anyone has a good suggestion on a high SP fan in the Pull configuration.
I really need it to be as quiet as possible (silent would be best)
But also if there are fans with maybe red blades or the housing is red?
Adobe Photoshop Graphic Artist and PC Building Enthusiast
Corsair 750D | I7 4770 | Aorus Waterblocked 1080ti | z97A Gaming 7 MSI | EVGA supernova 750 G2 Gold | 900P 280Gb 256GB 850PRO 128 GB 850 EVO| 32GB Corsair Vengeance (4x8GB) | Logitech g502 mouse | Corsair K70 Cherry-MX Brown | Full Custom Water Cooling Loop |
https://linustechtips.com/topic/409377-fans-for-rad/
SP120 quiet edition with red rings?
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/409377-fans-for-rad/#findComment-5513894
I see there being 2 ways of going with this: Either you go the DIY route or the off-the-shelf solution.
DIY solution being, taking a good static pressure fan and painting it the color you want. For example doing what Snef did in his Gold Wings project to the EK-Waterblocks Vardar fans.
For the off-the-shelf solution, I would choose Corsair's SP series fan, with the red outer ring
The DIY solution might bring you better results, but you are going to have to do some work for it. But there's always the extra flair you get with DIY  ;)
https://linustechtips.com/topic/409377-fans-for-rad/#findComment-5513923
I think the sp120s are the easiest solution
Thanks guys :)
https://linustechtips.com/topic/409377-fans-for-rad/#findComment-5516139
