PWM Splitter on ASUS Z97-Deluxe fan header
Solved by runit3,
Would it be safe to plug two fans into one header on an ASUS Z97-Deluxe motherboard using this splitter? http://www.noctua.at/main.php?show=productview&products_id=74&lng=en
I want to make sure I'm not trying to draw too much power through it, or anything else detrimental.
Thanks in advance!
Depends on the amp draw of the fans. Every ASUS board (Z87/Z97/X99) I've owned has a maximum draw of 1A on each fan header.
Learned this when I contacted EK about their Vardar requirements, .52A per fan, needed 1 header for each fan.
