hey guys I think my pc has some problem.. when I shutdown my pc, sometimes it doesn't turn off entirely but displays bluescreen very quickly [(almost millisecond) and luckily i recorded the bsod event after 6-9times of 10min per playing then it restarts.. after it will stuck in the mobo logo something and will not startup..   im worried because I thinks it is hardware problem. almost all parts ain't 1yrs old after bought.
here's the pic
  • My Mid Gaming Build
  • CPU: i3-4150 l Motherboard: ECS B85H3-M l RAM: Kingston HyperX Fury 1X4GB CL10 1600MHz l GPU: Powercolor R7 260X 2GB GDDR5 OC l Case: HP Vectra VL420 MTStorage: (1)Seagate 250 & (2)500GB: (3)Samsung 320GB 7200rpm l PSU: Corsair VS 550 l Display(s): LG Flatron L1710B 1280x1024Cooling: 120mm Fan, Adda Fan 80mm, CPU Bearing FanKeyboard: Keyboard A4 Tech Natural A Keyboard (KRS-83) l Mouse: CDR KING TM7008 3D Optical PS/2 l Sound: D'Sound M325 2.1 Speaker
https://linustechtips.com/topic/408708-help-frequent-pc-bluescreens/
here's the pic
If you actually bothered to read it tells you what to do...
My Build: Phoenix
Processor: Intel i7 4770k, Motherboard: Asus Z97-P RAM: Corsair Dominator Platinum 16GB GPU: MSI GTX 1050TI OC Case: Corsair ICUE 4000X, Storage: Samsung 840 EVO 120GB + 500GB + 2TB HDD PSU: Corsair RM750, Cooling: Corsair H100i Capellix,
        If you want to talk to me or give me an answer, please tag me otherwise you'll be talking to thin air ❤️
Have you installed any new software or drivers lately?
Gaming/Folding rig: Coolermaster CM 690 II Advanced White | MSI Z77A-G43 | Intel Core i7 3770k @ 4.4GHz | 10GB G.Skill RAM | Nvidia GeForce GTX 780 | Samsung 840 Pro 128GB | Seagate 2TB | Seagate 2TB | WD Blue 640GB | Cogage Arrow (Passive) | Thermaltake Toughpower XT 675w | Windows 10 Pro
Photography
please post specs
also check your ram, that could be it
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
please post specs
i3 4150 and r7 260x.. hey i already listed my specs in my profile ummm.. how to view it to others?
no.. before and after i install a software. it frequently happening
try putting it in your signature
it started when we using Corsair vs 550 psu breakdown and we RMA it and Im currently using a new generic psu 650W got in my brothers office...
note: it happens when my psu having problems if I play high demanding games and suddenly shutdowns (but not the case fans) and instant if we do furmark.
         I force myself to ignore it by web browsing but after few days. even light task (browsing, low demanding games) shutdowns, and now i decide myself to use
         a  temporary psu. no shutdowns afterall..  but the bluescreens still happening
Corrupt OS would be my next guess then, I'd do a fresh install of Windows, unless you can use system restore to a point before the bluescreen started happening.
Photography
I already did it. still happening. cant test my mobo cuz I have no extra lga 1150.. i tell my bro if he can borrow in his work (my bro is a pc tech.staff)
So I'm guessing I should reseat all my hardware.. do the basic troubleshooting. this symptom is very rare tho. at the first buy of mobo. there is present problem...
another bluescreen. i forgot what the problem but i remember afaik i installed the drivers of my mobo and its all gone.. maybe a bad mobo brand/... (ECS bullsh**) I have Should replaced the mobo in the firstplace but well. its all in past now. lessons learned.
    -sorry for bad english. im from philippines. i feel so ashamed
