Have you put it as the default boot drive in your bios?
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
https://linustechtips.com/topic/40840-ssd-detection-problems/#findComment-529018
You must set it as the boot drive in the BIOS first, assuming the SSD is functional.
https://linustechtips.com/topic/40840-ssd-detection-problems/#findComment-529029
What do you mean it sometimes boots? Are you saying the SSD is detected some times and not at other times? If that is the case, try using another 6Gbp/s port.
https://linustechtips.com/topic/40840-ssd-detection-problems/#findComment-529041
There should be something in the BIOS about boot priority. I have never used MSI's BIOS before, so you'll either have to play around with it, or wait for someone to help you with the BIOS.
https://linustechtips.com/topic/40840-ssd-detection-problems/#findComment-529063
