Need some Help, UEFI/GPT
1- Yes you need to convert your partition to GPT disk before you install WIndows. In fact, the moment you turn on UEFI mode, Windows 8 setup will refuse to install on MBR partition
2- CSM is needed if your graphic card is not GOP ready. Intel GPUs are GOP ready, Nvidia and AMD are not. To make an Nvidia or AMD graphic card GOP ready, you need to update the firmware from the manufacture of your card (ASUS, Gigabyte, MSI etc.), that will make it GOP ready. It must be noted that once your graphic card is GOP ready it will NO LONGER work under a BIOS system (the only reason why Intel works with or without CSM is because the system updates the firmware automatically so it works), nor a non fully supported UEFI system. Also, not all graphic card from the manufacture can be made GOP ready. It really depends if the manufacture wants to support it, also if they put an upgradable firmware chip (some can't be written to), and finally, some put firmware chip is too small for fitting a GOP ready firmware. As the graphic card will no longer work for BIOS, many manufactures don't put the graphic card firmware public, you need to contact tech support to have it. Hopefully in the future, we have a switch on the graphic card or jumper system to switch between the classic firmware and GOP ready firmware on the graphic card.
3- Secure Boot doesn't slow down the boot process. So you can leave it off.
4- I don't understand you.
