Dark Rock 3 heat sink does not fit with ram installed AMD BUILD
Solved by MourningSouls,
We checked and with the hardware we were given there was no possible way to mount it facing front to back.
I forgot AMD has a very rectangular setup.
That sucks. 3 options. Return the cooler and buy something else. Return the RAM and buy something low profile. Pull the heatspreader off the closest DIMM.
Pretty sure option 3 will void a warranty.
For those who want to see a DP3 on an AMD board.
http://www.kitguru.net/wp-content/uploads/2011/07/IMG_3863-WM.jpg
