car cooling liquid
it's an alienware aurora R4, and it's really overheating, it goes up to 86C maybe even more, temp is around 55C while it's idle, i looked it up, and it wasn't just him, many others had the same problem, they had to clean their liquid cooling, and if i can not open it to fix the issue, that means changing the whole thing to buy a new one, which will kinda cost alot... , some even reported that the radiator was not cleaned before it was mounted
i did ask a friend where i could find distilled water, and he said it's easy , i didn't know that before so that's my bad....
however, am i supposed then to use 100% distilled water or add the antifreeze as u mentioned?
Adding distilled water and anti-freeze will work especially with the dissimilar metal issue since the rad is most likely made of aluminum. Depending on the anti-freeze you get it can have biocide in it which is the stuff you want to prevent bacterial growth, if you can't find that stuff something like copper sulfate or iodine should be added also.
