Hey.
Is there anyone that knows how to remove this popup? If I am gaming GTA V in fullscreen, and I push on the caps lock key, it goes in to window mode because of this popup.
Please help!
Do you have custom keyboard drivers installed?
https://linustechtips.com/topic/407409-caps-locknum-lock-popup/#findComment-5490045
This is not part of Windows. You have installed a program that does this.
Usually Keyboard software does that. Look through it's options and make sure the pop-up notification is disabled, or remove the software.
If that is not it, then it is another software that you installed. Look through your startup programs.
https://linustechtips.com/topic/407409-caps-locknum-lock-popup/#findComment-5490851
I tried to uninstall my Steelseries program, but it is still poping up. And I don't know if I have a custom program for my keyboard.. If you can name a few I might recognize it?
Or is there a way to see what program that are in action while I am pressing CapsLock? Like some program that shows witch program who uses CPU usage.
https://linustechtips.com/topic/407409-caps-locknum-lock-popup/#findComment-5495478
Task Manager does this.
CPU: i5 4690K  CPU Cooler: Corsair H100   Motherboard: Gigabyte Z97X UD3H   Memory: G.Skill (2 x 4GB) DDR3-1866   Storage: Samsung 830 Series 128GB 2.5" SSD/Seagate Barracuda 1TB 3.5" 7200RPM   GPU: EVGA GeForce GTX 660 Ti SC 2GB   Case: Cooler Master CM 690 II (Black) ATX Mid Tower   PSU: CORSAIR Enthusiast Series TX650M 650W 80 PLUS BRONZE Certified   Optical Drive: MSI DH-24AAS-17 R DVD/CD Writer   Operating System: Windows 10 Pro (64 bit)
https://linustechtips.com/topic/407409-caps-locknum-lock-popup/#findComment-5495578
