mATX or mITX case custom loop
I'm carrying over a 2.5" SSD from my R4, so M.2 isn't really important to me.
My question now is about pump/res options in the 804. I have a dual bay XSPC pump/res combo now, so Id need to downsize.
Is there a difference between D5, Laing and DDC pumps? can I get away with a small combo unit, like the EK XRES 140, and just velcroing it, or should I get a seperate bigger res, and try and hide the small pump somewhere?
Also, how would I go about setting up a drain port/would it be necessary in this case? Should I just use a quick disconnect at the lowest point?
Thanks
Res size doesn't matter Adding a big res is just like a buffer in case you get a leak you'll have more time to notice before you go dry, Also for looks. All adding more water to your loop will do it make it take slightly more time before your coolant reaches its max temp (you'd need like a swimming pool for it to make a difference), so something like the EK xres 140 is fine.
Yes a quick D/C at the lowest point would be fine, your going to want a drain and fill port somewhere on you loop, otherwise its not gunna be fun when you need to replace your coolant. Also you could get a multiport top for the ek xres and remove one of the plugs to fill/drain your loop, you'd just need to turn your case to that the port was at the lowest point.
Edit: Something to be mindful about though is all those D5 Res combo kits are brand specific, you can't use EK tops on Bitspower Tubes ect ect, you have to use EK with EK, Bitspower with Bitspower. Fittings are fine though they are all G1/4 Threads (as long as they are advertised as G1/4 anyways).
