Hello, so one of my friends just got back from being on vacation and when he got home his computer stopped working. When you turn on the computer all the lights and fans turn on, you can hear the hard drive and see that the motherboard is on. I have tried taking out the gpu and just trying to run it but that didn't show signal still so I was wondering if this is possibly a dead cpu or something and how to test this.
CPU: i5 somethin bought like 2-3 years ago
GPU: Sapphire 7950
Specs: Intel i7-4790k | Corsair H60 | Asrock Z97 Pro4 | 4x4g Corsair Vengeance | Gigabyte g1 970 | Sandisk u110 128GB SSD | 1TB Toshiba Hard Drive | Corsair RM750 | Corsair Air 540 4 Corsair AF120 LED Purple 2 Corsair AF140 LED Purple
https://linustechtips.com/topic/406971-no-signal-dead-cpu/
If u have a speaker, u can diagnoze it by beeps.
It can be also a dead mobo tho. Speak would help much.
I do not have a speaker but I dont get how it would be a dead mobo if the light is on 0_O
https://linustechtips.com/topic/406971-no-signal-dead-cpu/#findComment-5484339
Are you sure it's a mobo/cpu/gpu issue?
It may depend on your ssd... I remeber reading about ssds not working after not beeing used for a long time.
CPU: Intel i7 4790k @4.00Ghz - Motherboard: ASRock Z97X Killer - RAM: HyperX Savage Kit 2 x 4 GB - GPU: Inno3D iChill Geforce GTX 970 Ultra - Case: NZXT Noctis 450 - Storage (1st): Samsung SSD 850 EVO 120GB - Storage (2nd): Seagate 2TB HDD - PSU: Evga Supernova 750 G2 80+ Gold
https://linustechtips.com/topic/406971-no-signal-dead-cpu/#findComment-5484388
Oh, that's not your pc... mai bad :(
https://linustechtips.com/topic/406971-no-signal-dead-cpu/#findComment-5484393
There are many variations of how it's 'dead'. In most cases lights and power are 'on', but it won't post.
Anyways, I would get a speaker and\or try another mobo with this cpu.
https://linustechtips.com/topic/406971-no-signal-dead-cpu/#findComment-5484791
GPU: Sapphire 7950
Try the basics first. One stick of RAM at a time, GPU removed, use onboard graphics.
Process of elimination. If your friend didn't unplug the system while they were away the PSU could have been damaged by a surge. Lots of things can happen, especially when no one is looking.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/406971-no-signal-dead-cpu/#findComment-5485768
If there's no beep signal, first try another cpu, my p67 extreme4 scared me, it turned out to be the g520 cpu that's not working.
Bulgarian, WoT nick- ivelinv8, War Thunder- BEST_NOOB_BG, GAMING PC: FX-4170; R9 280X TOXIC; 16 GB RAM; Fortron Raider 750W; Raidmax Helios case; WD Green 1TB. 50Mb/s + 50% bonus
https://linustechtips.com/topic/406971-no-signal-dead-cpu/#findComment-5487081
The only other cpu I have is my 4790k and I rather not take it out of my computer. I did not hear a beep so I dont know
I have tried to take out gpu and use onboard graphics but still nothing I will try only using one stick of ram at a time.
I mean everything is turning on but it wont post so ya. I got my computer that I could swap our parts with but I just rather not take apart my computer. I got a speaker but I did not hear any sounds while during it on.
https://linustechtips.com/topic/406971-no-signal-dead-cpu/#findComment-5488511
Well, ask a friend, try the cpu on your mobo.
Did you try resetting the bios?
https://linustechtips.com/topic/406971-no-signal-dead-cpu/#findComment-5489393
