Motherboard Problem
Go to solution Solved by pwn_intended,
What does that mean?
The CPU that you have chosen in your link is NOT a Haswell refresh CPU. I dont know how to be more clear...
the CPU isnt a haswell architecture meaning its not haswell meaning
u dont have 2 do anything
Its not a Devils Canyon, but it is a Haswell Refresh CPU. It was released in May of 2014. As long as the Z87 board was manufactured after that date it will have the BIOS update already applied.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/406628-motherboard-problem/#findComment-5480288
