i was just checking out stuff on ebay
and i found this
http://www.ebay.com/itm/8W-2-4Ghz-Wifi-Wireless-Broadband-Amplifier-Router-Power-Range-Signal-Booster-/171043840789?pt=US_Networking_Boosters_Extenders_Antennas&hash=item27d301e315
i know the laws
1watt rule etc
the confusing thing is i know that a 2 watt amp with heatspreaders heat up a bit here is a quote from a review of a well known 1 watt amp on ebay "the AMP gets really hot... burned out after about 9 months actually..."
and iv see 4 watt amps as big as a dvd case
this small thing is 8 watts without heat spreaders
and 109 already sold as seen on the link
any body have any exp with any kinds of amps because they are supposed to be pretty hot right ?
is there a catch ?
If your grave doesn't say "rest in peace" on it You are automatically drafted into the skeleton war.
https://linustechtips.com/topic/40658-8watt-wireless-amp/
One thing. Do not use anything over 1W. Ever.
Is needs to be, use repeaters, but using such powerful amps is going to interfere with anything wireless within at least a hundred feet.
Seriously, don't use this.
https://linustechtips.com/topic/40658-8watt-wireless-amp/#findComment-527622
read my post again
im asking why doesn't this burn up
1 watt amps already heat up a lot
FCC's law = 1 watt limit
its not an issue
https://linustechtips.com/topic/40658-8watt-wireless-amp/#findComment-528116
