panda Antivirus uninstall Problems
Go to solution Solved by Jlryan,
Reboot to safe mode and try uninstalling from there.
Hi guys. I wanted to uninstall panda internet security with free antivirus trials,
because it is just a horrible program, slowing my Surface pro 3 down by alot.
Now mid uninstall everything freezes, forcing me to do a hard reboot. not even task manager or charms would work :'(
Now everything turned on again but the frigging panda program is still here.
When i try to uninstall it through the programs menu a Spanish error message pops up telling me that something went wrong
and pointing towards some error log in the temporary data of my pc
How do i get this program of mah damn PC?!?!?!
PS: Panda bricked my surface already back in spring when they released a bad update,
but i thought they have learned from their mistakes so why not try it out again?
http://www.zdnet.com/article/panda-antivirus-mistakenly-flags-itself-as-malware-breaks-pcs/
post-239898-0-31610600-1436781630_thumb.
post-239898-0-35358000-1436781634_thumb.
https://linustechtips.com/topic/406301-panda-antivirus-uninstall-problems/
Gaming/Folding rig: Coolermaster CM 690 II Advanced White | MSI Z77A-G43 | Intel Core i7 3770k @ 4.4GHz | 10GB G.Skill RAM | Nvidia GeForce GTX 780 | Samsung 840 Pro 128GB | Seagate 2TB | Seagate 2TB | WD Blue 640GB | Cogage Arrow (Passive) | Thermaltake Toughpower XT 675w | Windows 10 Pro
Photography
It worked! Thank you so much! finally got rid of this pesky shitty Antivirus
No worries! :)
Also, I'd recommend Avast!, It's great once you turn off the silly features it has (browser addons and rating system) and set it to silent/gaming mode. Not had an issue involving virus/malware for the last 5+ years while using it with Malwarebytes.
Photography
No worries! :)
Is it the free or paid version you use? I already have malwarebytes, used it with win defender together but win defender is just so annoying.
It will randomly start scanning your pc in the middle of a gaming session
I've always used the free version :)
And to be honest I completely disable Windows Defender / Security essentials haha, it's far too annoying.
Photography
