When i try to use the compressed air in a can there is a liquid that comes out of the can and evaporates from the surface where i sprayed in about 1sec. Will this liquid damage pc components if i use it on my pc and is the can defective or is it normal (the can is supposed to be used for cleaning tech)
https://linustechtips.com/topic/405669-pc-dust-cleaning/
that is bad and it will damage your pc! make sure to not spray while the can is upside down!
https://linustechtips.com/topic/405669-pc-dust-cleaning/#findComment-5467203
Shouldn't cause any problems, but I would buy another can if it worries you. They are dirt cheap anyway :)
i5 4690K | Asus Ranger VII | 8GB HyperX Fury | Asus GTX 780 | NZXT H440 | Samsung 850 Evo | Seagate Barracuda | Corsair RM 750W | Corsair H105
E3-1246 v3 | Asus Gryphon Z97 | 8GB HyperX Fury | MSI GTX 970 | Enthoo Evolv mATX | Samsung 840 Evo | WD Red | EVGA SuperNova GS 650W | NZXT Kracken x41
https://linustechtips.com/topic/405669-pc-dust-cleaning/#findComment-5467277
