|  Athlon 750K   |   EVGA GTX 750 Ti FTW  |  Acer Aspire E15 - i5 6200u, 940M  |
|  Sennheiser HD 518   |   FiiO E10K DAC and Amp  |
Moto G (1st Gen)
https://linustechtips.com/topic/405150-need-mobo-advice/#findComment-5460810
Cheap - MSI z97 Gaming 3/ Gigabyte Krait
Sweetspot - Msi Z97 Gaming 5 or 7/ Asus z97-a
Expencive: Asus z97 ws
Personally i have the z97 gaming 5 and its excellent overclocks well has support for sli and is all around excellent
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/405150-need-mobo-advice/#findComment-5460817
1
https://linustechtips.com/topic/405150-need-mobo-advice/#findComment-5460824
Mate that a bull leg black and yellow motherboard are heckla expensive. I also heard you want some ketchup with the bbq chicken, therefore i throw this bad boy in hope ya like it. http://www.amazon.com/Asus-MAXIMUS-VII-HERO-Motherboard/dp/B00K2MASE4/ref=sr_1_1?ie=UTF8&qid=1436636141&sr=8-1&keywords=maximus+vii+hero << ASUS Maximus VII Hero Z97
https://linustechtips.com/topic/405150-need-mobo-advice/#findComment-5460835
what chipset should i pick for this cpu? just askin?
for 4460 H81 or B85 is good enough.
Also motherboard don't affect performance, so even if you plan to upgrade CPU later don't spend too much, get the cheapest one with all the features you need.
This is one of the cheapest Z97 MBOs and should be good enough for 99% of people http://pcpartpicker.com/part/gigabyte-motherboard-gaz97mxgaming5
MSI gaming 3/5/7 are also great MBOs and they are also red :) compare their features and decide which one is best for you :)
https://linustechtips.com/topic/405150-need-mobo-advice/#findComment-5461391
