Hey guys!
update/upgrade from last build log.
what did i do?:
i did switch from the phantom 240 case to the S340, and bought a kraken X61 cpu cooler.
What did i paint: SSD Cover, 280mm Radiator, mounting screws for the cooler bracket and the EVGA Backplate.
For the poeple who are gonna ask why i didn't go for the Krait edition, i already had this motherboard and didn't really wanted to spend another 100buks for a different collor.
i used white gloss plasti dip, i did 6 coats with 10min between every coat.
i didn't want to post 22 pictures, so here's a link to the album for it: http://imgur.com/a/DAG44
System
  • CPU
    i7 4790k 4.4ghz
  • Motherboard
    MSI Z97-G55
  • RAM
    ADATA 8gb 2x4
  • GPU
    EVGA GTX 970 Superclocked acx 2.0
  • Case
    NZXT S340
  • Storage
    240gb ssd crucial
  • PSU
    EVGA 850W Supernova G2 (yes overkill)
  • Cooling
    Kraken X61
Specs: Ryzen 9800X3D 5425MHz - ASUS TUF RTX 4080 super - G.Skill Trident Z5 Neo 64GB 6400MT/s CL26 -  Gigabyte X870 AORUS Elite Wifi7 ICE - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua NH-U12A
https://linustechtips.com/topic/405117-my-gaming-system-updated/
what u use for paint
https://linustechtips.com/topic/405117-my-gaming-system-updated/#findComment-5460348
how is the kraken x61 pump noise ?
my pump is actually dead silence, but since i have the radiator tubes on the top now, i can hear now and then a air bubble wich is quite anoying.
before i had the radiator in the top of my phantom 240 and there was no sound what so ever.
i might have to shake the case a bit to fix the airbubble, but it should go away overtime.
overall it's quiet and it cools really well.
https://linustechtips.com/topic/405117-my-gaming-system-updated/#findComment-5460394
I would get a locked CPU, and an H97 and see if you can get a better GPU.
i can buy a 980ti or titan if i want to right now, but i don't see the extra money making it worth for me right now.
i run every game i have on good settings and it performance really good.
thank you for the recommendation anyways!
https://linustechtips.com/topic/405117-my-gaming-system-updated/#findComment-5460459
Please buy yourself a msi krait for the sake of everyones OCD everywhere.
i know i know, but like i said above, i'm not gonna spent 100buks for just the white collor, + i don't really mind since the lights are blue aswell
https://linustechtips.com/topic/405117-my-gaming-system-updated/#findComment-5470310
  • 2 weeks later...
small update,
it's nothing special or epic or anything like a crazy mod, but i wanted to have some kind of art work on it.
i wanted to do something with the S340 front pannel so this is what i did:
https://linustechtips.com/topic/405117-my-gaming-system-updated/#findComment-5586059
