I want to know if the parts i chose out for a pc i plan to build will work. Any help is appreciated :)
PCPP tells you. Yes those will all work together.
What is your budget for the PC and what parts do you have already?
I want to know if the parts i chose out for a pc i plan to build will work. I'm fairly new to pc building, so i'm not a 100% sure if all my components will work together or not. Any help is appreciated  :)
Make sure to follow your thread to get notifications on replies
Also, all of those parts will work together. It looks like you took that screenshot from PCPartPicker, which should tell you of any compatibility issues.
"I believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party."
-Ron White
