Need Help Again (Im Sorry )
Go to solution Solved by Oshino Shinobu,
As far as I know, the only way to check is to either look at the details on the box, or look at the PCB.
Ok So
I have 2 things i need to ask of you guys.
1. i need to know witch waterblock fits my card theirs 2 and i dont know where to find or know what version my card is. my card can be found here.
http://www.amazon.com/MSI-GTX-970-GAMING-100ME/dp/B00TPLKR7Q
and the two water blocks are
(A)https://shop.ekwb.com/ek-fc970-gtx-tfx-nickel
(B)https://shop.ekwb.com/ek-fc970-gtx-tf5-nickel
2. I HAVE A GREAT IDEA ok ok listen here now SLEEVED MICE like you custom sleeve your mouse but you cant fit anything over the usb but i need a way to do it any ideas ?
https://linustechtips.com/topic/404704-need-help-again-im-sorry/
1) I'm pretty sure it's the TFX one based on the fact that by now, MSI should have their revised PCBs in.
CPU: Intel Core i7 5960X @4GHz cooled by a Corsair H110i GT | MBO: Asus X99 Sabertooth | RAM: Crucial Ballistix Sport 32GB DDR4 (4x8GB 2400MHz) | GPU: Gigabyte G1 Gaming GTX 980 | SSD: Samsung SM951 M.2 SSD | HDD: 1TB Western Digital Black Drive | PSU: Corsair HX750i | Case: Corsair Obsidian 450D
https://linustechtips.com/topic/404704-need-help-again-im-sorry/#findComment-5455704
1. Booth fit and 2 maybe get the usb connector off somehow and solder it back on??
The first won't if you have an old PCB version.
https://linustechtips.com/topic/404704-need-help-again-im-sorry/#findComment-5455708
-SNIP-
You will need to check the revision of that card on the PCB but as for sleeving the mice cables, you can cut off the USB plug and sleeved and re-solder a new plug on which will give the cleanest look:
http://www.vetco.net/catalog/images/PAN-AN-AS-BK-1.jpg
https://linustechtips.com/topic/404704-need-help-again-im-sorry/#findComment-5455731
