I've got a TP Link TL-WN881ND wireless card in my system. The wifi connection will completely cut off randomly therefore not allowing me to connect to any networks at all. At first I thought my router went offline but checked on my phone, WiFi network seemed fine and working. The only way to resurrect the connection is to reboot the machine. This is the second time since it has happened, anyone have any ideas what is causing it?
https://linustechtips.com/topic/404689-wireless-pci-issues/
Was it working before?/ did you try unplugging it /re plugging it into the PCIE slot? if not try that, usually works for me
Soon as it goes offline that it, reboot and its normal, Going to have to reseat it, that's annoying since my machine is underneath the desk in a small spot or could it be since it is very close to the wall affecting the antennas?
https://linustechtips.com/topic/404689-wireless-pci-issues/#findComment-5455806
