I moved my room around and found one of my old monitors that I could use. When I hooked both up, only the old monitor was working. Here's my setup:
  • Crossover 290M>DVI-D>Displayport (DVI-D to Displayport adapter) [Main monitor]
  • Dell S2340L>VGA>DVI-I (VGA to DVI-I adapter) [Old monitor]
  • HDMI>TV
  • Zotac AMP! 980
Picture of the control panel HERE
Picture of the Nvidia control panel HERE
This is the only way my setup would work with my 980. My Displayport will not work. I tried everything to get it to work. I know for a fact all the adapters and cables work because I used them previously (on another graphics card). I also tested the displayport isolated, and still nothing will show up. Could my graphics card have bad Displayports (I tested all Displayport ports)? Is there anyway to fix this? Any response will be greatly appreciated! :)
https://linustechtips.com/topic/404681-displayport-issues/
