You sure FRAPS is recording at the FPS you want it to record at? Also, recording is intensive. It's writing massive files to your hard drive.
https://linustechtips.com/topic/40468-help-fraps-250fps-10fps/#findComment-523636
Look into MSI Afterburner or Dxtory. They don't eat nearly as much of your FPS as Fraps do. That said, I think you'll have a hard time recording 1080p on your system.
https://linustechtips.com/topic/40468-help-fraps-250fps-10fps/#findComment-523651
Yep i know that i am having the same result with other software like dxtory and bandicam
I'm so sorry but it look as if you're going to perish in the next 24 hours, the only way to end this curse is if you find a way to make Fraps work properly. Good luck.
Intel Pentium A800501-60 60MHz, 4MB RAM, 160MB Hard Drive, Voodoo Video Card, Windows 3.11 OS
https://linustechtips.com/topic/40468-help-fraps-250fps-10fps/#findComment-523734
Its probably set to 10fps to save file size.
 Asus M5A99X Evo  - AMD FX-8350 - 16GB Corsair Vengeance 1866Mhz - Corsair 120mm Quiet Edition Fans BenQ XL2411Z- EVGA GTX 980 Superclocked Fractal Design Define R4 - Corsair H100i - 2 TB 7200rpm HDD - Samsung 840 Evo 120GB - Corsair RM750w PSU - Logitech G502 Proteus Core - Corsair K70 RGB MX Red - Audio Technica M50x + Modmic 4.0 - LG 23EA63V x2
Spinthat Spinthat Spinthat Spinthat
https://linustechtips.com/topic/40468-help-fraps-250fps-10fps/#findComment-523742
  • 4 weeks later...
Make sure the HDD you are recording too has a reasonable Trasfer speed. Read and Write RW. Make sure you have not locked the fram rate.
Otherwise. TIME FOR A NEW PC!
CPU: AMD FX-8350 | CPU Cooler: Xigmatek Dark Knight Night Hawk | GPU: MSI TF3 7970 BE | Motherboard: M5A99FX-Pro-Rev 2.0 | RAM: Corsair Vengence LP 8GB (2x4) | PSU: Xigmatek Vector G 750W 80+ GOLD | Case: Thermaltake A71 | Storage: Seagate 1TB + WD 650GB
https://linustechtips.com/topic/40468-help-fraps-250fps-10fps/#findComment-640877
