Today my mom said I could get skyrim my first m game. I have some questions. I have 50$ so should I buy regular or legendary and how to install mods not from workshop? Also any recommended first time mods
Desktop 1: CPU: Intel Core i7 4770  GPU: Nvidia Geforce GTX 960 Ram: Crucial DDR3 2x8GB 1600 MHz  Storage: Samsung 850 Evo 250GB and Segate 1TB Hard drive  Desktop 2: CPU: Intel Pentium G3258  GPU: AMD R7 250  Ram: Corsair Vengance DRR3 2x8GB 1600 MHz  Mobo: MSI H81M-E33  PSU: Corsair CX430M  Case: Rosewill MicroAtx Mini Tower
https://linustechtips.com/topic/404521-skyrim-questions/
- How much is Legendary over regular?
- Google Skyrim Nexus. And use Mod Organizer
https://linustechtips.com/topic/404521-skyrim-questions/#findComment-5453595
20$
https://linustechtips.com/topic/404521-skyrim-questions/#findComment-5453599
Some mods require legendary, so might be worth it depending on the mods you want to play.
Check out Gopher's channel, he has playlists on how to install mods.  Some can be a bit of a process so it's worth it to watch the vids.
https://www.youtube.com/user/GophersVids/playlists
Dis track?  Jesus christ why'd we even fight a war?  - Ron Cadillac
https://linustechtips.com/topic/404521-skyrim-questions/#findComment-5453605
20$
I would say yes.
https://linustechtips.com/topic/404521-skyrim-questions/#findComment-5453613
Ok installing.
https://linustechtips.com/topic/404521-skyrim-questions/#findComment-5453630
I would say yes.
What are some good first time mods?
https://linustechtips.com/topic/404521-skyrim-questions/#findComment-5453647
You will probably need SKSE (not on Nexus mods) and SkyUI (on Nexus) to begin with.
And other than that I would probably recommend Dual Hand Combo Keys. Good mod that allows you to switch magic or weapons with a click of a number.
I would also recommend all unofficial patches (they are a few of the most downloaded mods on the Nexus too. There are 4 which solve some glitches)
https://linustechtips.com/topic/404521-skyrim-questions/#findComment-5453688
The unofficial patches are absolutely necessary in my opinion. From there it basically depends on what you want and what your computer can handle, but I'd recommend a good vanilla playthrough so you can appreciate the game on its own merits.
Edit- Immersive Armors and Immersive Weapons add a bunch of new stuff to the game, even if you're like me and usually don't use what it adds, it makes the various npcs in the world look more varied.
"Ghost"
Intel i5-4690k 4.6 GHz 1.25v | NZXT Kraken x61 | Asus Z97-AR | 2x8GB Kingston HyperX Fury 1866 MHz | EVGA GeForce GTX 1080 FTW DT 2050 MHz
NZXT h440 White | EVGA SuperNOVA 850 GS | 2x Samsung 850 Evo 500 GB + Seagate Barracuda 2TB  |Asus VG248QE  | Win 10
https://linustechtips.com/topic/404521-skyrim-questions/#findComment-5458622
Where can you get the patches?
https://linustechtips.com/topic/404521-skyrim-questions/#findComment-5481478
NM
Never mind I found them.
https://linustechtips.com/topic/404521-skyrim-questions/#findComment-5481488
