Hey there guys, I just bought the clevo p650se and installed windows 7 on it. However, as there is no disk drive, and I dont not have an external one, I can't use the windows 7 disc drivers that come with it. Can someone give me advice on how to start everything?
You can download the ISO from microsoft directly and create a usb stick
http://www.microsoft.com/en-us/software-recovery
https://linustechtips.com/topic/404212-help-with-clevo-p650se/#findComment-5449998
I already installed Windows 7
Sorry you meant the drivers >< my mistake
everything you need will be on each companies site, eg graphics drivers from nvidia, intel chipset stuff from intel,
if not, if you have any other PC in the house, copy the driver disk to a usb stick
https://linustechtips.com/topic/404212-help-with-clevo-p650se/#findComment-5450039
Aye, one question though. when installing intel chipset, at hm87, it got stuck for a long time, so i cancelled the installation. Is it supposed to take really long or ?
https://linustechtips.com/topic/404212-help-with-clevo-p650se/#findComment-5450049
It can take a while, its  not 100% essential to install though,
https://linustechtips.com/topic/404212-help-with-clevo-p650se/#findComment-5450053
if you have another computer you can copy the files onto an external harddrive and then run it off that, thats what i did :)
Do you guys know how to calibrate the best display for the laptop? Looks abit blurry coming from a rMbp, or is it normal?
https://linustechtips.com/topic/404212-help-with-clevo-p650se/#findComment-5450193
What display did you order
https://linustechtips.com/topic/404212-help-with-clevo-p650se/#findComment-5450196
It's an IPS Matte LCD
That didnt help :P they do a few versions, what resolution? if its 1080p thats an understandable reason to be less sharp than your retina display, if its 4k then it should be as sharp if not sharper
https://linustechtips.com/topic/404212-help-with-clevo-p650se/#findComment-5450214
haha sorry, its a 1080p. Everything's pretty damn sharp, I guess coming from a retina display you would feel abit weird, but I'll get used to it
https://linustechtips.com/topic/404212-help-with-clevo-p650se/#findComment-5450222
Yeah retina display is quite a bit higher resolution, will just take time to get used to
https://linustechtips.com/topic/404212-help-with-clevo-p650se/#findComment-5450238
Sorry, one more thing. I have a ssd+hdd, and whenever I install something it prioritises installing the the ssd, which is small. Is there anyway I can get it to always install in the HDD instead?
https://linustechtips.com/topic/404212-help-with-clevo-p650se/#findComment-5450271
I dont know about making everything do it by default
I just manually choose where I want my files to be installed, when you install the program just change the file path
For steam origin its much easier, create a directory for your other drives, when you install the game there is a drop down list
https://linustechtips.com/topic/404212-help-with-clevo-p650se/#findComment-5450281
Ah okay, no prob. thanks!
https://linustechtips.com/topic/404212-help-with-clevo-p650se/#findComment-5450286
You could try upscaling it
Other than selecting it each time for each download/install im not too sure if there is somewhere to set the default.  :(
- I am no match for ShadowCaptains response times. GG.
https://linustechtips.com/topic/404212-help-with-clevo-p650se/#findComment-5450291
sorry
not sorry
https://linustechtips.com/topic/404212-help-with-clevo-p650se/#findComment-5450598
I have this laptop as well. I'm assuming you have the sager rebrand? if not look up sager np8651 its the same laptop and they host drivers online. As for the blurry go to your screen resolution and change the dpi scaling to 100% makes it much better imo. I think windows defaulted at 125% on mine.
https://linustechtips.com/topic/404212-help-with-clevo-p650se/#findComment-5450686
I already had it at 100%, but thanks for this. I'll slowly, but hopefully quickly, get used to it. :)
https://linustechtips.com/topic/404212-help-with-clevo-p650se/#findComment-5450764
In case you need drivers again, they are available at http://www.clevo.com/clevo_down.asp?lang=en
Frost | 7700K @ 4.9GHz 1.36v, delidded | Asus DUAL GTX 1060 6GB OC | Corsair LPX 16GB DDR4 2800MHz | Samsung 960 EVO 250GB SSD + Toshiba 1TB HDD + Toshiba 2TB HDD + Samsung 860 EVO 1TB SSD for macOS | Asus PRIME Z270-A | Fractal Design Celsius S24 | Seasonic M12-II 620W PSU | Corsair 400C White | NZXT Hue+
Samsung Galaxy S8 | Stock
Ticwatch E (Black) | Ticwatch Brown Leather Strap
https://linustechtips.com/topic/404212-help-with-clevo-p650se/#findComment-5451298
sorry
not sorry
Few more things, on the right side, the usb port beside the SIM tray doesn't work, while the two others do. Is it my drivers, or is it simply not working? And, whenever I install synaptics driver, it says synaptics 64bit enhancements has stopped working. I can move the mouse with the touchpad, left and right click, but nothing else! I can't scroll, zoom etc.
And, for some reason, the GPU indicator constantly shows that my dGPU is being used, even from windows boot screen to current use! Why is this happening? I have drivers for both nvidia and intel graphics
https://linustechtips.com/topic/404212-help-with-clevo-p650se/#findComment-5451564
MySN and Eurocom have drivers on their sites, but some drivers better be the updated ones - like Nvidia drivers
https://linustechtips.com/topic/404212-help-with-clevo-p650se/#findComment-5451570
Try contacting your Clevo reseller. They should be able to fix this for you. Did Windows come installed on your machine? And in case you think you got the wrong drivers, you can buy a cheap external DVD reader/burner and run the autorun setup from the disk itself, or just copy it out on another machine and run it from a flash drive.
https://linustechtips.com/topic/404212-help-with-clevo-p650se/#findComment-5451691
