(sorry for bad english)
I just built a new pc 3 days ago and i didnt know about this forum :(
i want to ask if my system is ok for gaming games like witcher 3
are there any bottlenecks or is it running too hot?
I got:
Motherboard: Gigabyte X99-UD4
CPU: i7 5820k 3.3 GHz
RAM: 16GB 4x4 G.Skill Ripjaw 4 2400
GPU: gigabyte gtx 980
HDD/SSD: seagate 2T HDD / samsung 850 evo 250GB
Power: BeQuiet 600W straight power 80+ gold
CPU cooler: LC-CC-120-x3 Cosmo cool
im running about 40-45°C idle and i dont know jet hoch much under load because i had not much time to install stuff
so what do you guys think? and can you say how long it may be up to date?
(sorry for bad english again^^)
https://linustechtips.com/topic/403835-is-my-system-running-properly/
I got:
im running about 40-45 idle and i dont know jet hoch much under load because i had not much time to install stuff
Its not bad for gaming at all, but is it just for gaming? Try taking off the cooler and replacing the thermal paste and putting it back on. Sounds like it just didnt get placed right.
I got:
40-45 C is great on idle!!
A system like that will most likely be up to date for a while depending on what you do.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
can i take of the thermalstuff without that alcohol linus is using all the time?
Yes. That's perfectly fine. The substance you're referring to is isopropyl alcohol.
Idle temps don't mean shit unless it's crazy hot (60C+). Load temps are what matter.
and how hot should it maximaly get under load?
I'm no expert, but judging just by the size of the cooler, maybe 60s to 70s.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
http://imgur.com/ankjEBN
the pic is bad but i think you can see the most
there are 2 fas in the bottom front like the blue one
i dont know wich ones push air out and wich one pulls it in
and i only have 1 cpu fan installed cause i had not enough space for the other 2
It should be below 80 degrees if you have a decent CPU cooler. And you can indeed remove the thermal compound without alcohol but it's not as good as doing it with. Just make sure every little bit is off before applying the new compound.
Mah Build:  CPU: Intel i7-7700K COOLING: NZXT Kraken X52 GPU: Asus Strix GTX 1080 MOBO: Asus Strix Z270F RAM: 16GB GSKILL TridentZ RGB 3000
CASE: In Win 303 STORAGE: Samsung 850 EVO 250GB, Seagate 1TB  SSHD PSU: EVGA Supernova G2 750W
Where is the CPU fan? I don't see it.
after 1 hour of playing witcher on max settings i got up to max 62°C so am i still in "the green area"?
Those are great temps, you haven't got anything to worry about and that system is a beast, and should be able to max out most games for quite some time yet.
I would do some cable management though and tidy up the nest of cables in the bottom of your system, but that's up to you, if you don't feel like doing it then just enjoy it as is, but if you want something you can really be proud of, then tidy up the cables as best you can and make it look as awesome as it is :)
CPU: Core i5 2500K @ 4.5GHz | MB: Gigabyte Z68XP-UD3P | RAM: 16GB Kingston HyperX @ 1866MHz | GPU: XFX DD R9 390 | Case: Fractal Design Define S | Storage: 500GB Samsung 850 EVO + WD Caviar Blue 500GB | PSU: Corsair RM650x | Soundcard: Creative Soundblaster X-Fi Titanium
Click here to help feed our lasses Pokemon
