Hey guys!
This is my first build and I am very excited about it as I have only been able to game on my small laptop which is SUPER inadequate for my needs. Please tell me what you think, if i'm missing anything, or if you have any recommendations. Thanks!
Intel Core i7-4790K 4.0GHz Quad-Core Processor
Asus Z97 PRO GAMER ATX LGA1150 Motherboard
Team Vulcan 16GB (2 x 8GB) DDR3-1600 Memory
Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive
Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
EVGA GeForce GTX 970 4GB FTW ACX 2.0 Video Card
Enermax OSTROG ATX Mid Tower Case
Ultra X4 750W 80+ Bronze Certified Fully-Modular ATX Power Supply
BenQ RL2455HM 60Hz 24.0" Monitor
Razer BlackWidow Chroma Wired Gaming Keyboard
Corsair Vengeance M95 Wired Laser Mouse
https://linustechtips.com/topic/403418-my-first-gaming-pc-build/
If you're not doing rendering don't bother with the i7, and focus more on trying to squeeze your budget to an i5-4690k and a 980. You'll be much happier like that.
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
https://linustechtips.com/topic/403418-my-first-gaming-pc-build/#findComment-5439625
Uh oh I've just realized that I dont have an optical drive, is that something I need?
https://linustechtips.com/topic/403418-my-first-gaming-pc-build/#findComment-5439636
http://pcpartpicker.com/p/FGYtFT <----- That's a better all around base, however feel free to switch out parts that more suit your needs like case and such.
https://linustechtips.com/topic/403418-my-first-gaming-pc-build/#findComment-5439637
No, I bought one and then threw it away. Gaming on PC you'll literally almost never need an optical drive and if you get one get a USB one because they're portable and don't ruin the aesthetic of your case.
https://linustechtips.com/topic/403418-my-first-gaming-pc-build/#findComment-5439645
How will I install my operating system without one?
https://linustechtips.com/topic/403418-my-first-gaming-pc-build/#findComment-5439656
You use the ISO of Windows and burn it to a USB using programs like ISO to USB and then when you boot up your computer select the USB drive as the boot drive and you'll install windows like that. It's like using a DVD but instead you're using a USB.
https://linustechtips.com/topic/403418-my-first-gaming-pc-build/#findComment-5439667
Ohhh Thanks! You saved me quite a large chunk of cash as I just assumed you needed one
https://linustechtips.com/topic/403418-my-first-gaming-pc-build/#findComment-5439681
Nope :D If you need any help feel free to contact me, if you want I can message you my contact info, I build a PC almost every day so I can give you advice on what to do.
https://linustechtips.com/topic/403418-my-first-gaming-pc-build/#findComment-5439704
Sure that would be great! I need all the help I can get because I REALLY am afraid of something going wrong or something breaking.
https://linustechtips.com/topic/403418-my-first-gaming-pc-build/#findComment-5439749
