build pc now or wait?
so i shouldn't wait for skylake?
You are not going to like this answer, but you are in Unicorn Country here. Both answers to that questions are both right and wrong.
Waiting for the better technology could easily mean you wait for years since there is always a better technology just months away. At some point you are going to have to stop waiting and build a new system or go without for the rest of your life.
You can gamble and wait for Skylake to ship and then snap up the Haswell-E stuff at a discount. The bet you would be making is that the discount is worth the wait (the possibility exists that there will be no price drop on Haswell) and that you do not get a DOA component. You will also have to act within days to cash in on your wait, otherwise you will miss the odd "deals" here and there (if there are any).
Here are some questions to ask yourself:
Does your current system meet your current needs? By that I mean can you do the editing you want? Can you play the games you want and at the settings you want?
If the answer is "yes", then wait.
If the answer is "no" then you need to ask yourself, Can you put together the system you need with the budget you have?
If the answer is "yes", then build now.
If the answer is "no", then wait.
If your answer is to wait, you might be able to sock away some additional funds for an even better system.
