GTA V Problem
Hey guys,
I have a 144Hz monitor and discovered I had been playing at 60Hz in GTA so I decided to turn in to 144Hz and I dont know wtf happened. Now I am lagging crazily and tried changing some settings around. In GTA the usage bar was like halfway after I turned it 144Hz. I have no idea why I am lagging. If you guys could help that would be awesome.
Thanks
https://linustechtips.com/topic/403301-gta-v-problem/
Do you have vsync on?
GAMING RIG:
CPU: i9-14900k
MOBO: Gigabyte Z790 Aorus Elite AX
RAM: 64GB G.Skill Ripjaws S5 @ 6000MHz
GPU: Gigabyte Gaming OC ICE 16GB 9070XT
STORAGE: Crucial 1TB NVME (Boot Drive) / 2TB Crucial NVME / 4TB 990 EVO Pro NVME SSD
CASE: Dimas Tech EasyBench V3.0
https://linustechtips.com/topic/403301-gta-v-problem/#findComment-5438364
Hey guys,
Thanks
Whats your system specs?
My Rigs:
Gaming/CAD/Rendering Rig
Case:
 Corsair Air 240 , CPU: i7-4790K, Mobo: ASUS Gryphon Z97 mATX,  GPU: Gigabyte G1 Gaming GTX 970, RAM: G.Skill Sniper 16GB, SSD: SAMSUNG 1TB 840 EVO, Cooling: Corsair H80i PCPP: https://au.pcpartpicker.com/b/f2TH99SFF HTPC
Case:
Silverstone ML06B, CPU: Pentium G3258, Mobo: Gigabyte GA-H97N-WiFi, RAM: G.Skill 4GB, SSD: Kingston SSDNow 120GB PCPP: https://au.pcpartpicker.com/b/JmZ8TW
https://linustechtips.com/topic/403301-gta-v-problem/#findComment-5438367
The new patch has destroyed PC performance. Rockstar is aware of the issue and is working on a fix
https://linustechtips.com/topic/403301-gta-v-problem/#findComment-5438376
In your signature: What does SFF HTPC stand for?
CPU: Intel Core i5-4460Motherboard: Asus Z97-A/USB 3.1Memory: G.Skill Ripjaws X Series 8GBStorage: A-Data Premier Pro SP900 128GBGPU: Sapphire Radeon R9 290 4GB Tri-X OC Video CardCase: Corsair SPEC-01 REDPower Supply: EVGA 600BNetworking Card: TP-Link TL-WDN4800Monitor: Asus VG248QE 144Hz 24.0" MonitorKeyboard: Razer BlackWidow Tournament Edition (Cherry MX Blue) Mouse: Logitech G100s | Quote me and say "Dope Flamingo" if you actually read this.
https://linustechtips.com/topic/403301-gta-v-problem/#findComment-5438405
Small Form Factor    Home Theatre PC
My Rigs:
Case:
Case:
https://linustechtips.com/topic/403301-gta-v-problem/#findComment-5438418
