Hey guys, I was wondering if this is normal behavior for this cpu. I just got a used intel i7 3770k and put it on my Gigabyte Z77M-D3H. So it seems to be working fine although when i stress test it using prime95 every few seconds it goes from 4.2ghz to 1.6ghz. I know that intel has speed step but shouldnt it not be happening while the CPU is on full load? Would appreciate insight on this.
Temps:
Idle : 32
Load : 85 Max
Heres a screenshot if it will help
https://linustechtips.com/topic/403129-speed-step-problem/
Prime 95 is an unrealistic load, try occt or aida and see if the problem persists. It could be throttling
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/403129-speed-step-problem/#findComment-5435862
Although, before i maxed out the fans, it was reaching 100 degrees. it only throttled when it reached 105? i doubt the i7 throttles at 85 degrees. Ive seen my friends processors run at higher temperatures. Also, ive used prime 95 on my sandybridge i5, doesnt seem to act this way. Odd..
https://linustechtips.com/topic/403129-speed-step-problem/#findComment-5435999
Yes, but on anything after Sandy Bridge, Prime 95 overvolts the processor, therefore makes the CPU run hotter than it is supposed to. Stop using it before you do any permanent damage to your processor. Try Aida64 or Intel Extreme Tuning Utility. Both are excellent stability testing programs.
PS: If your friends' processors run hotter than 85C, then they are doing something wrong...
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/403129-speed-step-problem/#findComment-5436091
Prime only did that if Adaptive/Auto voltage was on. And from what I've seen so far they fixed the issue a long time ago.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/403129-speed-step-problem/#findComment-5436264
Well, a few things to note i guess is that we live in a tropical country where at times the ambient temp of the room reaches 40 deg.
My friends using a 3770k running at 4.5ghz, maybe thats why he reaches over 100. But despite reaching those temps, his doesnt seem to throttle (if that is whats happening) like mine which only gets to around 83 deg.
https://linustechtips.com/topic/403129-speed-step-problem/#findComment-5440273
Some motherboards allow to change temperature at which CPU throttles, but it's dumb to do so ( by raising that temperature ).
CPU-delided i5-4670k@4.6Ghz 1.42v R.I.P (2013-2015) MOBO-Asus Maximus VI Gene GPU-Gigabyte GTX 970 G1 Gaming@1582Mhz core/3744Mhz memory COOLING-Corsair H60 RAM-1x8Gb Crucial ballistix tactical tracer@2133Mhz 11-12-12-26  DRIVES-Kingston V300 60Gb, OCZ trion 100 120Gb, WD Red 1Tb
2nd  fastest i5 4670k in GPUPI for CPU - 100M
https://linustechtips.com/topic/403129-speed-step-problem/#findComment-5442970
P95 runs in sequences. At the end of every successful iteration it is likely the CPU usage will drop, then load up once the next iteration has begun. You can watch the readouts in P95 and correlate them to CPU usage, although task manager in 8.1 has never been known to be the most accurate thing in the world.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
https://linustechtips.com/topic/403129-speed-step-problem/#findComment-5442991
Although, when i use other computers, it doesnt act the same way, which is odd.
Here are some images on how it acts on aida64
http://puu.sh/iTzZ0/5cb6c6b816.png
http://puu.sh/iTA2q/d1cb23990b.png
https://linustechtips.com/topic/403129-speed-step-problem/#findComment-5449300
