Replacement for sata cable, Cooler Master V1000
Chiobe
http://www.coolermaster.com/powersupply/enthusiast-v-series/v1000/
I'm trying to find a replacement cable for the sata cables that came with the V1000.
It has only 3 connectors and I need 4 per cable. Yes, I will be running 12 HDD/SSD.
So does anyone know where I can buy one or get the parts to make 1?
Have you checked the cablemod.com? I'm sure they have to have one of them.
Otherwise, I see that almost every local store near me has them.
Yeah, they exist, but I dont want to replace all the cables for 3 cables.
Then just try to look at the local stores, Idk if someone would sell those cables in small quantity.
