Ok so im sitting here doing my work and im hearing this weird staticky sound threw my headset and i noticed the sound is in time with my mouse movement. So i muted my computer and the static sound is still happening when i move the mouse and its really bugging me as i have never noticed it before and was wondering if im just going crazy or if any one ells has ever had this happen?
Desktop: CPU: I7-5820K GPU: 980Ti, 750Ti PhysX Mobo: MSI X99A SLI PLUS RAM: 4x4 Kingston DDR4 2400MHz OS: Win10
Storage: 250GB Samsung Evo, 3TB WD Black and Green FIRESTRIKE, Reason for dedicated PhysX Card.
Peripherals: Screen: 3x BenQ VZ2350 Mouse: Razer Naga Keyboard: Some Dell Thing Sound: Razer Tiamat, 5.1 Logitech Surround Speakers
https://linustechtips.com/topic/402018-am-i-going-crazy/
You're experiencing EMI which is leaking into your audio signal, presumably from your video card.
https://linustechtips.com/topic/402018-am-i-going-crazy/#findComment-5420253
You're experiencing EMI which is leaking into your audio signal.
What is EMI?
https://linustechtips.com/topic/402018-am-i-going-crazy/#findComment-5420259
What is EMI?
Electromagnetic Interference. Technically EMI is incorrect as Electromagnetic is one word, not two.
https://linustechtips.com/topic/402018-am-i-going-crazy/#findComment-5420264
Could a dusty PC contribute to that?
I don't think so.
https://linustechtips.com/topic/402018-am-i-going-crazy/#findComment-5420271
I only dusted it out about a week ago xD, so what do you think would be causing it all of a sudden and how would i stop it if it keeps going.
https://linustechtips.com/topic/402018-am-i-going-crazy/#findComment-5420278
put some ferrite chokes on your USB cable that leads to your mouse. There is a reason that most high end mice come with one installed. (My sensei and G502 included.)
Hey! New SIgnature!
I'm supposedly a person on the Internet, but you'll never know if I'm human or not ;)
https://linustechtips.com/topic/402018-am-i-going-crazy/#findComment-5421871
Mine didnt and not not cheap :/ but how would i go  about putting them on the cable without damaging it?
https://linustechtips.com/topic/402018-am-i-going-crazy/#findComment-5427529
Why would it damage it? Just imagine the choke like a donut. What you want is for the cable to pass through the middle, make a loop around one side of the donut, and pass through the middle again in the opposite direction.
The choke opens in two halves so you don't need to modify the cable.
https://linustechtips.com/topic/402018-am-i-going-crazy/#findComment-5427558
https://linustechtips.com/topic/402018-am-i-going-crazy/#findComment-5428290
Well my headset is a razer tiamat so i have like 1 cable that spits to like 7 and a razer naga mouse
https://linustechtips.com/topic/402018-am-i-going-crazy/#findComment-5441404
