Like the title says guys. I want you guys to please recommend me a thermal paste on Newegg for my GPU. I have a GTX 560 (non Ti). I'm sure there are different rules as well compared to applying thermal paste on a CPU. This is my first time doing this so any tips would be extremely helpful to me.
https://linustechtips.com/topic/40195-best-thermal-paste-for-gpu/
https://linustechtips.com/topic/40195-best-thermal-paste-for-gpu/#findComment-519389
I would recommend Arctic Silver 5
CPU: Intel core i5 4670k @ 4.4ghz  CPU Cooler: Noctua NH-U9B SE2 GPU: GTX 660 Motherboard: MSI Z87M-Gaming RAM: Corsair Vengeance Low Profile 2x4gb Black @1.6ghz Power supply: Corsair HX650 80 plus gold Storage: Adata 64GB SSD + Seagate Barracuda 1TB Case: Corsair Obsidian 350d
https://linustechtips.com/topic/40195-best-thermal-paste-for-gpu/#findComment-519393
Thanks man I'll most likely get the MX-4
I use this for all my CPUs but thought it wouldn't be the best choice. I just don't want to risk losing my card.
i always use arctic silver 5 for anything never failed me
Yes, I have used it many times too but like I said in my reply to @LT Smith, I'm going to buy "higher quality" thermal paste just to play it safe with my card.
https://linustechtips.com/topic/40195-best-thermal-paste-for-gpu/#findComment-519418
IC Diamond thermal paste
ACS Systems - Jason Neal
My "Danger Den" PC: i7-4960x @ 4.5Ghz, ASUS X79 Deluxe, 3x GTX Titan Black, 6x m4 512GB, 64GB Corsair DDR3-2400, Corsair AX1500i
Black Beauty Workstation/LAN PC: i5-4570 @ 3.79 GHz, ASRock Z87E-ITX, XFX Double D R9-280 (Non-X), GSkill 8GB DDR3-2400
https://linustechtips.com/topic/40195-best-thermal-paste-for-gpu/#findComment-519421
Gelid gc extreme, Artic Mx-4, Noctua Nt-h1 are all good.
https://linustechtips.com/topic/40195-best-thermal-paste-for-gpu/#findComment-519423
Arctic Silver 5 is a good quality thermal paste. I just don't recommend it since it is highly conductive, and the risk of short circuiting is present.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/40195-best-thermal-paste-for-gpu/#findComment-519427
Thanks, I already decided on the MX-4 :)
Yeah I don't want it shorting out my card. :c
Thanks for the help and I'll post the results here.
https://linustechtips.com/topic/40195-best-thermal-paste-for-gpu/#findComment-519441
IC Diamond...
<p>CM HAF 922 (Akasa Apache 140s/120s for case cooling), ASUS Sabertooth Z77, Intel 3570K@4.0Ghz, 16GB Kingston Black @1600 (2x8), Xigmatek DK 2 with 2 xAkasa Apache 120mm, Sapphire 7950 OC CF, NZXT Sentry Mix 2 FC, 2TB Seagate Barracuda HDD x1, Kingston Hyper X 240GB SSD x1, Seasonic 1050w PSU, Cyborg V5 Keyboard with RAT 3 mouse, ASUS VG248QE 144mhz. monitor
https://linustechtips.com/topic/40195-best-thermal-paste-for-gpu/#findComment-520005
