I re-installed windows 8.1 on my new ssd, and now every time I download something, It goes on to the ssd.
I want to put everything on my hdd for storage, but it doesn't give me the option whenever I try to download a program
Not sure what to do, any help is appreciated.
make a Documents, downloads pictures music pictures etc folders
then change the directly of those to the hdd
https://linustechtips.com/topic/401936-hard-drive-storage/#findComment-5419292
All the user default folders can be moved to your storage drive. Here's the windows guide.
http://windows.microsoft.com/en-gb/windows/redirect-folder-new-location#1TC=windows-7
Also, what are you using to download stuff? If you're talking a web browser, you can just change the default download folder in the options.
https://linustechtips.com/topic/401936-hard-drive-storage/#findComment-5419411
Yes I am using my web browser
https://linustechtips.com/topic/401936-hard-drive-storage/#findComment-5419548
Well would it help?
if you need free space
if you need just delete windows files,
and turn on hidden folders and del those.
Wait the hdd had windows?
And you installed windows on the SSD
WAS THE HDD (with Windows ) INSTALLED WHEN YOU INSTALLED WINDOWS ON THE SSD???
https://linustechtips.com/topic/401936-hard-drive-storage/#findComment-5419671
No. Calm down lol
https://linustechtips.com/topic/401936-hard-drive-storage/#findComment-5419958
But for example, I just tried to download skype and put it on my Hard Drive. I made sure I configured it in chrome settings to download on my hdd. Well after I installed it and stuff I went and looked, and skype was still installed on my ssd, and not my hdd :/
However the setup for it was in my hdd.
https://linustechtips.com/topic/401936-hard-drive-storage/#findComment-5420002
When using the Skype installer, the screen that lets you select your language has a "more options" button underneath, which lets you install Skype to whatever directory you want.
You can install any program wherever you want, some installers just obscure the option for some weird reason.
Edit: Also it's worth noting that most people run their programs from their SSD as they load up faster.
https://linustechtips.com/topic/401936-hard-drive-storage/#findComment-5420060
Okay thank you. The only reason I want it on my hdd is so i have extra room for my steam games on my ssd.
Also can you clear up something for me? I heard that if you put a lot of information on your ssd (Ex, 230gb on a 250gb ssd) it degrades the lifetime of the ssd :/
https://linustechtips.com/topic/401936-hard-drive-storage/#findComment-5420126
SSDs have a limited number of writes before they start to degrade, this limitation is just inherent to the technology. That being said, newer SSDs will last for ages (it was more a problem for the first generation of SSDs), just treat it like you would any other drive imo, you'll probably have upgraded to a new system before it dies.
Edit: Just to be clear, this isn't how full the drive is, it's based on write cycles, so for example filling the hard drive with data, wiping it, filling it up again, you can only overwrite the data on the flash memory a certain number of times until it starts to "wear out". But like I mentioned, SSDs have improved a great deal, and newer ones have lifespans beyond the length of time you'll most likely be using it (under normal use). So again, don't worry about it, and just use it normally.
https://linustechtips.com/topic/401936-hard-drive-storage/#findComment-5420195
Awesome, thank you for clearing that up :)
https://linustechtips.com/topic/401936-hard-drive-storage/#findComment-5420347
