I hope LN2 was used.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/401709-dat-cpu-voltage-doe/#findComment-5415778
Stick the radiator in an IceBucket and go for a joyride.
Stick the radiator in a bucket full of LN2 and go for a joyride.
Either way works lol
https://linustechtips.com/topic/401709-dat-cpu-voltage-doe/#findComment-5415805
Nope.
I hope a high end cooler was used*
https://linustechtips.com/topic/401709-dat-cpu-voltage-doe/#findComment-5415806
