Help with First Build
Solved by Lion & Stag,
Ladies and gents, I give to you Lobo. See a (bad) photo I took here: http://1drv.ms/1hhK0X7
Thanks to all who helped me out with this build, I finally got it up and running today, overclocked the CPU to 4.4GHz and GPU to 1400 MHz boost and memory from 7010 MHz to 8010 MHz.
Here are my scores on the Unigine Heaven Benchmark 4.0
FPS:
59.2
Score:
1492
Min FPS:
32.3
Max FPS:
135.3
I plan on running a Cinebench benchmark soon but so far, all is good!
