Using a OS again
Solved by GoodBytes,
Exactly! The last thing you want is to be be trap buying a new license.
If you really want Windows 7 for cheap, and you are NOT a student, see if you have an old Windows XP not in use somewhere, if you do, you are illegible for Windows 7 Upgrade. The Upgrade license of Windows 7, no mater what was the license of the previous Windows, will be retail. So you can transfer it to another computer. Yes you do a clean install with Windows 7 Upgrade, if you wonder.
Same for Windows 8 Upgrade, but OEM is cheaper if not mistaken.
