Hi,
I have a 4790k + h110i gt and i have big temps, 40 in idle. Case is: fractal design define r5 and the radiator is installed in front.
Can you tell me where i installed wrong ? Thank you,
Maybe try putting the rad in the top?
What are your OC specs? Maybe you turned the voltage up to high.
 My Buyer’s Guide!
Build:
CPU: Intel Core i5 4690K Cooler: Cryorig R1 Ultimate RAM: Kingston Fury White Series 8GB SSD: OCZ 100 ARC 240GB HDD: Seagate Barracuda 1TB Motherboard: MSI Z97S SLI Krait Edition Graphics Card: Powercolor PCS+ R9 390 Case: Phanteks Enthoo Pro (White) Power Supply: EVGA G2 750W Monitor: LG 29UM67-P 29" 21:9 Freesync Sexiness Mouse: Razer Deathadder ChromKeyboard: Razer Blackwidow 2014 Headset: Turtle Beach Ear Force XP400
https://linustechtips.com/topic/400874-high-temps/#findComment-5403775
thats normal...
Favourite Game:
The Elder Scrolls IV Oblivion -[https://en.wikipedia.org/wiki/The_Elder_Scrolls_IV:_Oblivion]
The Elder Scrolls IV: Oblivion is an action role-playing video game developed by Bethesda Game Studios and published by Bethesda Softworks and the Take-Two Interactive subsidiary, 2K Games. It is the fourth installment in The Elder Scrolls action fantasy video game series, following The Elder Scrolls III: Morrowind and preceding The Elder Scrolls V: Skyrim. Oblivion was first released in March 2006.
Favourite Music:
Look at my Mixcloud [https://www.mixcloud.com/Gabelele/]  If you want
PC specs:
-Pentium G3258
-GTX 750ti
-8gb no name RAM
-MSI h81m-e34
-240gb Kingston SSD now SSD
-1tb Seagate baracuda HDD
-500watt Aero cool 'X-strike' PSU
-Bitfenix Neos (Blue Y Black)
- Modded Microsoft -Intelli mouse [linustechtips.com] (thanks to TheRandomness X/)
-Logitech K120 keyboard
-ASUS 21.5" 1080p monitor
No mates facts:
Favorite tank: Sturmgeschütz III (I understand the Sturmgeschütz series are not technically tanks but infact SPGs, 'got me')
Favorite Aircraft: Henschel Hs 129
Roles or characters in games:
WarThunder = Tank destroyer and sometimes my KV-1B if im bored
CSGO = Sniper, I seem to be able to AWP 'well' apperently
RPGs in general = Mage or Tank w/ resoration
https://linustechtips.com/topic/400874-high-temps/#findComment-5403777
Well I think we need to start off by gathering a bit more information, can post your full build, possibly a picture with the pump and radiator setup inside the case and some temps while performing stress tests(i would recommend using the Intel XTU program). Then we can make more recommendations.
https://linustechtips.com/topic/400874-high-temps/#findComment-5403792
Hi,
Try getting some Arctic silver 5 thermal compound and putting that on there. That's what I did and I have about 10-25 degrees cooler under load and around 5-10 at idle...
CPU: i7-8700K I CPU Cooler: Noctua NH-D15 GPU: ROG Strix 1080 Ti MoBo: ROG Strix Z370-E RAM:  G.SKILL Ripjaws V Series 32GB (2 x 16GB)   PSU: CORSAIR HXi Series HX1000i Case: Corsair Air 540 Display: 24" 1920X1080p 144Hz ASUS - 27" 2560X1440p 144Hz Dell OS: Windows 10 Home 64bit
https://linustechtips.com/topic/400874-high-temps/#findComment-5403799
i7 4790k + asus maximus vii hero + h110i + fractal design define r5
and a pic with
https://www.dropbox.com/s/59xi0lqb1dohldx/Photo%2005.07.2015%2C%2014%2039%2058.jpg?dl=0
@Bangflop if the problem is thermal compound, il change, but i dont think this is the problem.
Edit: in 4 minutes i will post intel xtu 5 minutes stress.
https://linustechtips.com/topic/400874-high-temps/#findComment-5403847
and a pic with
photo doesn't seem to be working for me...
i think the best information we can get is from a short stress test, go grab the Intel XTU program, install and run a quick stress test. 40c isnt bad for idle if your case has poor air flow or ambient temperatures are high(btw how warm is it in the room) my 4790k in a room at 72 deg F idles at 32-33c with very good air flow.
thermal compound is always a good starting place(remember pea shaped and about the size of a VRM capacitor(the little silver cans around the cpu socket)), if you're planning/needing to buy some i would recommend the noctua NT-H1 as per the cost and the tomshardware guide huge indepth thermal compound test from a year or two ago.
https://linustechtips.com/topic/400874-high-temps/#findComment-5403877
i see your picture now, do you have the fractal fan installed in the front of the case? if so the 2 corsair fans are installed backwards, they are pushing air out the front of the case, remember the fan has little arrows on the side to show airflow direction and on most fans the fan hub support is the end that the airflow comes out of. i would start by flipping the corsair fans around as a good first step.
https://linustechtips.com/topic/400874-high-temps/#findComment-5403905
Hi,
The air flow to the bottom fan probably isn't the best, but not sure it should be that would make a difference, double fan rad is pretty over kill without any over clocking.  Whats the temp of your room? Also make sure your tubing isn't kinked reducing flow, also make sure your fans are properly orientated.  The stock thermal paste is fine, it won't make that big of a difference, I'm using the stock stuff on my h100i and I idle with temps of about 33 degrees.
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
https://linustechtips.com/topic/400874-high-temps/#findComment-5403911
Yeah I'm about in the same boat as you. I have a stock H100i witha i7-4790K and I idle around 30 degrees and the highest I've ever seen it go is 62...
https://linustechtips.com/topic/400874-high-temps/#findComment-5403930
Yes, the 2 fans are pushing outside the case and i have 1 single rad who push air in case, so is like a push-pull with 3 vents.
I need to change the orientation of the fans ?
The ambient temp in room is 27.1
@Maaxtraxx what ? to put the psu with face down ? I can do that :)
https://linustechtips.com/topic/400874-high-temps/#findComment-5403932
and a pic with
It's not that the compound is bad or anything but the aftermarket silver 5 compound is extremely good and even if you just got the cooler and the preaplied paste is fresh and still good, the silver 5 will still give you a noticeable difference in temps.
https://linustechtips.com/topic/400874-high-temps/#findComment-5403949
i just purchased a fractal r5 myself, the case comes with 1 fan preinstalled in the front in the upper position, it is setup preinstalled to push air into the case which means if it is still there it is pushing air against the top corsair fan and 2 fans blowing in the opposite directions at one another will generally mean 0 air flow, that is why i was concerned about the fan orientation. also, the general rule of thumb is to have the front of the case draw air in(it is also designed to filter intake air in the front) and the back of the case push air out to maintain an air flow moving in one direction through the case.
https://linustechtips.com/topic/400874-high-temps/#findComment-5403973
i'm running an overclocked i5 under 55C on stock Noctua paste, premium thermal pastes are for serious overclocking only. Why pay inordinate amounts for premium products when you can have something less expensive that gives a slightly lesser result but still does the job perfectly fine?
A tube of the Silver 5 is only $8 so it's not really a premium and if you want cooler temps even if you ware not OCing, then I would get better paste...
https://linustechtips.com/topic/400874-high-temps/#findComment-5403979
the temperatures you're getting are definitely high, my thoughts are on 2 things:
first: flip the corsair fans around so they are pulling air in from the front of the case, if the 1 preinstalled fractal design fan is still installed then it is already pulling air in from the front.
second: I agree with reapplying the thermal compound and checking the spread and contact you got with the preinstalled compound.
third: I have a h100i GTX that was experiencing the same problem, after trying everything I could... I finally found this problem, I made a rather long post about what I found and what I did to correct it... that is if none of the above fixes your problem. it seems to be a problem specific to some Corsair AIO coolers not having enough mounting pressure(possibly due to these specific pumps having a bad cooler bracket design(behind the mobo) or improper tolerances of some sort.
http://linustechtips.com/main/topic/383857-temps-w-i7-4790k-and-h100i-gtx/
https://linustechtips.com/topic/400874-high-temps/#findComment-5404025
I own an R5 too, you can't mount a rad in the front without removing those fans really, it just plain won't work without a lot of messing around
OP, put the rad on the top, it'll benefit your cooling plus it means you don't have a HDD bay getting int he way of your airflow.
Good recommendation to put the rad on top. With my R5 putting the radiator in front was really easy, I simply removed the preinstalled fractal fan and attached the radiator behind it and then put both fractal fans that came with the case in the front in a push configuration then installed the corsair fans in a pull configuration.
post-230666-0-39035900-1436047176_thumb.
https://linustechtips.com/topic/400874-high-temps/#findComment-5404075
Noctua NH-T1 is good quality stuff, there's no need for me to go out and buy tubes of thermal paste for one degree of difference. I run at 55C under full load, I don't think I can do much more to that to make a difference
http://www.tomshardware.com/reviews/thermal-paste-performance-benchmark,3616.html
Toms hardware agrees... NT-H1 is one of the best and easiest to apply compounds out there
https://linustechtips.com/topic/400874-high-temps/#findComment-5404099
Sorry pix, didn't mean to hijack your thread with off topic discussions. i'll repost my pertinent though:
http://linustechtips...-and-h100i-gtx/
https://linustechtips.com/topic/400874-high-temps/#findComment-5404125
Thank you guys.
Now i do this surgery.
+ I changed the position of PSU
- il change corsair fan's orientation
- il change the thermal compound
And should i both fractal vents in front of rad ?
I personally did install both fractal fans in the front, pushing into the case and then installed a corsair AF-140 in the back of the case blowing out, either way it is most important to have the fans blowing in the proper direction.
Cant wait to hear how it all works when you're done!
https://linustechtips.com/topic/400874-high-temps/#findComment-5404175
thats normal...
stupid comment, normal for such a cooler is mid 20s idle if you dont live in the desert, its either had a bad install or the pumps failing and needs an rma, it also depends on what prime95 you use, 26.6 gives a lot lower temps than 28.6.
my bad you said xtu, thats even worse youre getting temps that high on there, prime95 isnt even that bad.
Gpu: MSI 4G GTX 970 | Cpu: i5 4690k @4.6Ghz 1.23v | Cpu Cooler: Cryorig r1 ultimate | Ram: 1600mhz 2x8Gb corsair vengeance | Storage: sandisk ultra ii 128gb (os) 1TB WD Green | Psu: evga supernova g1 650watt | Case: fractal define s windowed |
https://linustechtips.com/topic/400874-high-temps/#findComment-5404234
Ok i did what you guys said and now i have with 8-10 degrees lower on intel xtu, means 79-83.
Tomorrow i will buy one more vent to put in the front. Is a good temp now, or i should put the rad on top ? I didnt wanted to remove the top noise canceling, but i will do if this isnt good.
Edit: and 37-38 degrees on quiet mode now.
https://linustechtips.com/topic/400874-high-temps/#findComment-5404639
